[Qgis-user] matplotlib not found on Mac OS
Etienne Tourigny etourigny.dev at gmail.com
Wed Jul 25 04:16:22 PDT 2012
On Wed, Jul 25, 2012 at 7:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Agus,
> OK.
> It is working now.
> I got the blue dots with lines when I hover into the tiff map.
> Do this means that matplotlib is working, right?
yes
> Noli
> On 7/25/12, Agustin Lobo <Agustin.Lobo at ictja.csic.es> wrote:
>> ok, you are finding the same problem than I, please read my
>> original message: move the message window outside the map area and
>> click either Yes or No
>> Agus
>> On Wed, Jul 25, 2012 at 12:05 PM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Agus,
>>> Thanks for this tif file.
>>> However, when check ( )Active (Shif +A).
>>> I got this message:
>>> "There are no statistics in the following rasters:
>>> AFNDVI
>>> Calculate?
>>> No and Yes
>>> When I selected Yes. Stiill the message box would go away.
>>> The same with No.
>>> What must be the problem?
>>> Noli
>>> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>>>> use this:
>>>> http://dl.dropbox.com/u/3180464/AFNDVI.tif
>>>> Agus
>>>> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>>>>> I don't have a raster file right now. (This is new macbookpro). So a
>>>>> can't check right now.
>>>>> Noli
>>>>> On 7/25/12, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
>>>>>> Most probably no checkbox - because no pyqwt! Are the dots in the
>>>>>> graph red (qwt) or blue (matplotlib) ?
>>>>>> Etienne
>>>>>> On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>>>> No.
>>>>>>> There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
>>>>>>> The Graph checkbox toogle: i)Graph and grid (Layer and Value).
>>>>>>> Noli
>>>>>>>> and do you have the option to select qwt or matplotlib?
>>>>>>>> Thanks
>>>>>>>> Agus
>>>>>>>>> Hi Agus,
>>>>>>>>> I activated in View -> Panels and I can see the graph (i.e x,y
>>>>>>>>> axis)
>>>>>>>>> when I checked the checkbox. I think this plugin is working in Lion
>>>>>>>>> which uses python 2.7.
>>>>>>>>> Are you using Snow Leopard?
>>>>>>>>> Noli
>>>>>>>>>> Thanks Noli.
>>>>>>>>>> Go to View/Panels and you can activate it there.
>>>>>>>>>> Then display a multilayer raster and check both qwt and
>>>>>>>>>> matplotlib.
>>>>>>>>>> If matplotlib is working for you then most likely is that I've
>>>>>>>>>> done
>>>>>>>>>> something wrong in the installation.
>>>>>>>>>> Will check this evening and report back.
>>>>>>>>>> Agus
>>>>>>>>>>> I am using Mac OS X Lion.
>>>>>>>>>>> Installed Value Tool plugin, however, I don't not find the value
>>>>>>>>>>> tool
>>>>>>>>>>> menu.
>>>>>>>>>>> Where is it located?
>>>>>>>>>>> How to do you check if matplotlib is not find by value tool?
>>>>>>>>>>> I sucessfully installed contour plugin which use matplotlib and
>>>>>>>>>>> shapely.
>>>>>>>>>>> Noli
>>>>>>>>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>>>>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>>>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>>>>>>>>> matplotlib
>>>>>>>>>>>>>> despite
>>>>>>>>>>>>>> it is installed.
>>>>>>>>>>>>> How did you install matplotlib?
>>>>>>>>>>>> I installed matplotlib following directions in
>>>>>>>>>>>> http://www.kyngchaos.com/software/python
>>>>>>>>>>>> and using the dmg provided there.
>>>>>>>>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>>>>>>>>> version on valuetool which can use either qwt or matplotlib)
>>>>>>>>>>>> cannot
>>>>>>>>>>>> find it.
>>>>>>>>>>>> I'm just a casual user of qgis on Mac, so please could any other
>>>>>>>>>>>> more
>>>>>>>>>>>> experienced Mac user
>>>>>>>>>>>> help on testing this?
>>>>>>>>>>>> Thanks
>>>>>>>>>>>> Agus
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> Qgis-user mailing list
>>>>>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Dr. Agustin Lobo
>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>> Lluis Sole Sabaris s/n
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
>> e-mail Agustin.Lobo at ictja.csic.es
>> https://sites.google.com/site/aloboaleu/
