[Qgis-user] Change the Field type (.dbf)
Christine geo.guide at web.de
Fri Jul 27 08:36:43 PDT 2012
SÅ‚awomir Bienias wrote
>     I need to have Attribute Table with specific type of field - Integer
>     (4,0).
>     Is there any way to change field type in DBF table in QGis?
Have you tried in QGIS to write the content of your real field to a new
integer (4) field using the attribute calculator ?
[Open attribute table > toggle editing > Open field calculator (right button
below attribute table, should be active) ]
Create a new field with Definition Integer 4 and give it a NewFieldName. In
the expression field write: "OldFieldName"
Did a test and it worked with a shapefile.
Regards, Christine
View this message in context: http://osgeo-org.1560.n6.nabble.com/Change-the-Field-type-dbf-tp4991387p4991409.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
