[Qgis-user] Qgs file not working on second computer
Ramon AndiƱach custard at westnet.com.au
Mon Jul 30 21:08:17 PDT 2012
On 31/07/2012, at 11:31, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
> On Tue, Jul 31, 2012 at 12:11 AM, Ramon AndiƱach <custard at westnet.com.au> wrote:
>> Hi,
>> I have a QGIS project that is saved on on computer1, and is causing a silent crash when opened on computer2.
>> The same dataset saved as a project on computer2 will open on computer1.
>> I'm looking for some pointers about where to look to solve this problem.
>> -ramon.
>> _____
>> More details.
>> - Both these computers are win7 64-bit.
>> - Both are installed via OSGeo
>> - There are some differences in the plugins on both computers (Computer2 has less than Computer1); but none of the layers should depend on plugins.
> don't assume that!  Try to disable all plugins and see if it resolves
> your problem. You can runt qgis with --noplugins option to disable
> plugins temporarily.
> Etienne
I've now tried that. No luck on that one.
I also forgot to say that running from the command line does not give any errors either.
- ramon.
