[Qgis-user] Qgs file not working on second computer
Etienne Tourigny etourigny.dev at gmail.com
Mon Jul 30 20:31:59 PDT 2012
On Tue, Jul 31, 2012 at 12:11 AM, Ramon AndiƱach <custard at westnet.com.au> wrote:
> Hi,
> I have a QGIS project that is saved on on computer1, and is causing a silent crash when opened on computer2.
> The same dataset saved as a project on computer2 will open on computer1.
> I'm looking for some pointers about where to look to solve this problem.
> -ramon.
> _____
> More details.
> - Both these computers are win7 64-bit.
> - Both are installed via OSGeo
>  - There are some differences in the plugins on both computers (Computer2 has less than Computer1); but none of the layers should depend on plugins.
don't assume that!  Try to disable all plugins and see if it resolves
your problem. You can runt qgis with --noplugins option to disable
plugins temporarily.
Etienne
>  - Computer2 had a standalone 1.7 installed, but this was removed *before*
> 1.8 was installed.
> - Files for the project are on a central server and the project uses relative paths so it shouldn't be a file location issue.
> - The project does not use any custom CRS.
> - The project does have OTF set.
> - There is one image in this dataset that if it isn't displayed (doesn't have to be removed) the project loads.
>  - The drivers for this raster are installed, but even then other rasters of this type are working normally.
>  - On Computer2 this file will load the file on its own without problems.
> - I can not see any obvious differences in the :
>  - project files themselves, or
>  - the debugview logs; other than that the log on Computer2 stops abruptly.
> Qgis-user mailing list
