[Qgis-user] Google earth kml file not opening in Qgis
Ralf Wessels gis at ralf-wessels.de
Tue Jul 31 07:30:56 PDT 2012
Andre is right - qgis (like other gis systems too) cannot display
points, lines and polygons in one layer. It has to be either points or
lines or polygons. In a kml-file this is no problem.
So if you try to load a kml-file with points, lines and polygons, qgis
just loads the first object (and all same objects e.g. points) which is
saved in the kml-file.
Try to change the display order of the kml-file in Google Earth and you
will see the effect.
ralf
Am 31.07.2012 14:51, schrieb Andre Joost:
> Am 31.07.12 14:32, schrieb Andre Joost:
>> Am 31.07.12 14:03, schrieb Ralf Wessels:
>>> maybe it is an old kml-version?
>>> try to open it in Google Earth (actual version) and save it again - to
>>> be sure
>>> to have a valid file.
>>> ralf
>> No change, but:
>> Importing kml gives a list of layers to select. If I dont select
>> anything, i get nothing ;-)
>> As long as I have only one folder in the kml, it opens at once.
> Just another thing: It is possible to have points and tracks in the
> same folder with Google Earth kml, but Qgis does not like that, and
> displays only one geometry type.
> HTH,
> André joost
> Qgis-user mailing list
