[Qgis-user] missing tabs/panel in the map composer
Sake Wagenaar sw1234 at planet.nl
Tue Jul 31 23:09:32 PDT 2012
In the Print Composer, put the mouse pointer over the menu bar, click
the right button and select both Item properties and Composition.
Op 1-8-2012 7:38, maning sambale schreef:
> Dear all,
> I accidentally closed the removed the tabs/panels in the Map Composer.
>   How do I get it back. In the main QGIS window there is View > Panels.
>   I can't see a similar option in the Map Composer window/dialog.
