[Qgis-user] missing tabs/panel in the map composer
maning sambale emmanuel.sambale at gmail.com
Tue Jul 31 23:52:11 PDT 2012
Great.  Thanks!
On Wed, Aug 1, 2012 at 2:09 PM, Sake Wagenaar <sw1234 at planet.nl> wrote:
> In the Print Composer, put the mouse pointer over the menu bar, click the
> right button and select both Item properties and Composition.
> Op 1-8-2012 7:38, maning sambale schreef:
>> Dear all,
>> I accidentally closed the removed the tabs/panels in the Map Composer.
>>   How do I get it back. In the main QGIS window there is View > Panels.
>>   I can't see a similar option in the Map Composer window/dialog.
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
