[Qgis-user] (no subject)
Paolo Cavallini
cavallini at faunalia.it
Tue Mar 13 23:28:52 PDT 2012
Il 13/03/2012 23:59, Alister Hood ha scritto:
> Recent examples I can think of are the Contour plugin (I think its dependencies
> are available now, after the switch to Python 2.7 in OSGeo4W), and the plugin(s?)
> that require Rpy or whatever it is that isn't available since the switch to Python
> 2.7. And for a long time before that on Windows some of the plugins that used R
> (I'm not sure if they're the same ones which can't be used now) could only be used
> with quite an old version of R.
Contour plugin is deprecated, as its functionality is now included in the raster
menu. Rpy2 is a known upstream problem.
> I remember several other examples, but the details
> don't spring to mind.
Please do not spread FUD. A missing lib is a rather exceptional occurrence, and
happens mostly with a few experimental plugins.
> It might not be. But if you think people don't generally report bugs on windows,
> who knows?
I run tens of courses, with hundreds of users, mostly on Win. So I should know.
> Actually, in the past when I used the OSGeo4W packages I had even more crashes on
> that Windows 7 machine, so I'm wondering if there's something wrong with the
> machine...
Probably it's a local problem.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
