[Qgis-user] GDAL utf-8 workaround
Andre Joost andre+joost at nurfuerspam.de
Fri Nov 2 00:03:50 PDT 2012
Hi Ramon,
I agree with you. I fixed the utf-8 issue by inserting
SET SHAPE_ENCODING=UTF-8
at the beginning of the qgis.bat. No problems since then.
HTH,
André Joost
Am 02.11.12 05:41, schrieb Ramon Andiñach:
> On windows, with OSGeo packages, doing that will probably create other problems.
> -ramon.
> On 02/11/2012, at 12:28, Vladimir Naumov<sendmeoffer at gmail.com>  wrote:
>> Dear Sotiris,
>> the problem was fixed months ago. Try new GDAL 1.9.2
>> Regards,
>> Vladimir.
>> 01.11.2012 23:30, S. Koukoulas (lists) пишет:
>>> nice one!
>>> I did something similar by saving Greek fields in a new table (in
>>> Libreoffice Calc) and then used a common field to join them back to the
>>> attribute table. This can also be used to change from other greek
>>> encodings to utf-8 (through Libreoffice Calc) - a workaround until the
>>> problem is fixed...
>>> sotiris
>>> On 03/23/2012 04:34 PM, Koos Hagg wrote:
>>>> Hi everyone,
>>>> Trying the value 'utf-8' (no quotes) in a .cpg file did not work for
>>>> me (caps or not)
>>>> But i did find that i could get around the problem for now by opening
>>>> my shapefile's .dbf with Libreoffice Calc, (which opens it fine) and
>>>> saving the dbf (save as, same name, overwrite).
>>>> So at least that's a simple way to fix that for the time being.
>>>> Koos
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
