[Qgis-user] GDAL utf-8 workaround
S. Koukoulas (lists)
sotkouklistes at gmail.com
Fri Nov 2 04:37:37 PDT 2012
hmm.. are we talking about the same problem?
I use Fedora and gdal version 1.9.1-10 in my PC and windows xp in the
lab where I use QGIS 1.8.0 for an introductory course in GIS.
the problem is:
When I load a shapefile with greek encoding other than utf-8 (e.g.
iso8859-7 or wp1253), I can not see the greek characters properly. When
I load an iso8859-7 file, in the properties is set as utf-8 by default.
When I change this to iso8859-7, it does not accept the change (returns
back to utf-8).
As a result I have to load the file (or part of the table and use join
later) in Libreoffice, and save it as utf-8 in order to see greek in qgis.
Also, when I edit a file and write in greek, it does not save it as
greek! (no workaround for this so far!)
So I was referring to this problem, is there any solution? Is this
solved in a newer version of gdal? Would QGIS 1.8.0 work with a newer
version?
As an example try dowloading the SHP file from
http://geodata.gov.gr/geodata/index.php?option=com_sobi2&sobi2Task=sobi2Details&catid=16&sobi2Id=21&Itemid=
and see whether you can read the greek names (nomoi_okhe.shp)
best
sotiris
In my PC, I use :
Linux 3.5.4-1.fc17.x86_64 x86_64
System: Fedora release 17 (Beefy Miracle)
KDE: 4.9.2
On 11/02/2012 09:03 AM, Andre Joost wrote:
> Hi Ramon,
> I agree with you. I fixed the utf-8 issue by inserting
> SET SHAPE_ENCODING=UTF-8
> at the beginning of the qgis.bat. No problems since then.
> HTH,
> André Joost
> Am 02.11.12 05:41, schrieb Ramon Andiñach:
>> On windows, with OSGeo packages, doing that will probably create
>> other problems.
>> -ramon.
>> On 02/11/2012, at 12:28, Vladimir Naumov<sendmeoffer at gmail.com> wrote:
>>> Dear Sotiris,
>>> the problem was fixed months ago. Try new GDAL 1.9.2
>>> Regards,
>>> Vladimir.
>>> 01.11.2012 23:30, S. Koukoulas (lists) пишет:
>>>> nice one!
>>>> I did something similar by saving Greek fields in a new table (in
>>>> Libreoffice Calc) and then used a common field to join them back to
>>>> the
>>>> attribute table. This can also be used to change from other greek
>>>> encodings to utf-8 (through Libreoffice Calc) - a workaround until the
>>>> problem is fixed...
>>>> sotiris
>>>> On 03/23/2012 04:34 PM, Koos Hagg wrote:
>>>>> Hi everyone,
>>>>> Trying the value 'utf-8' (no quotes) in a .cpg file did not work for
>>>>> me (caps or not)
>>>>> But i did find that i could get around the problem for now by opening
>>>>> my shapefile's .dbf with Libreoffice Calc, (which opens it fine) and
>>>>> saving the dbf (save as, same name, overwrite).
>>>>> So at least that's a simple way to fix that for the time being.
>>>>> Koos
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
