[Qgis-user] Error linking last trunk.
Andrea Peri aperi2007 at gmail.com
Sat Nov 3 06:03:56 PDT 2012
Thx for response Giuseppe.
I forget to say I'm try-ing to compile the qgis-server only section.
With this change to components:
WITH_BINDINGS OFF
WITH_DESKTOP OFF
WITH_MAPSERVER ON
Now I'm try-ing to compile using the default settings.
But it say me this error in make phase:
sip: Deprecation warning:
/usr/share/sip/PyQt4/QtCore/qabstractfileengine.sip:266: Annotations should
not be used in explicit C/C++ signatures
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qfile.sip:138:
Annotations should not be used in explicit C/C++ signatures
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qobject.sip:237:
%GetCode should be used a sub-directive
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtextstream.sip:125:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtimer.sip:49:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:33:
%Module version number should be specified using the 'version' argument
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:66:
%OptionalInclude is deprecated, use %Include and the 'optional' argument
instead
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qapplication.sip:114:
%AccessCode should be used a sub-directive
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qshortcut.sip:42:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtXml/QtXmlmod.sip:33:
/home/archivio/tomcat/software/qgis/Quantum-GIS/python/core/core.sip:1:
/usr/share/sip/PyQt4/QtNetwork/QtNetworkmod.sip:33: %Module version number
sip: QgsComposerItemGroup::items() unsupported function return type -
provide %MethodCode and a C++ signature
make[2]: *** [python/analysis/sipanalysispart0.cpp] Error 1
make[1]: *** [python/CMakeFiles/python_module_qgis_analysis.dir/all] Error 2
Instead with the settings reported.
I can do a no error compile but have the reporte error:
-- Removed runtime path from "/usr/local/bin/qgis_bench"
CMake Error at postinstall/cmake_install.cmake:40 (INCLUDE):
  include could not find load file:
/home/archivio/tomcat/software/qgis/Quantum-GIS/build-master/postinstall/PostInstall.cmake
Call Stack (most recent call first):
  cmake_install.cmake:51 (INCLUDE)
Now I try your hints.
Thx,
2012/11/3 Giuseppe Sucameli <sucameli at faunalia.it>
> Hi Andrea,
> On Sat, Nov 3, 2012 at 12:59 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > compiling last trunk I see this error a linking time.
> > Is it linking to other users ?
> I'm unable to reproduce it on my Ubuntu 11.04.
> Try to re-run cmake (or ccmake) before make.
> Regards.
> >>-- Installing: /usr/local/share/qgis/i18n/qgis_mn.qm
> >>-- Installing: /usr/local/bin/qgis_bench
> >>make: *** [install] Error 1
> > Thx,
> > Andrea Peri
> > qwerty àèìòù
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli - Faunalia
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121103/ac17d8fe/attachment.html>
