[Qgis-user] Dissolve function with various modules
Paolo Cavallini cavallini at faunalia.it
Sat Nov 3 22:35:34 PDT 2012
Il 20/08/2012 09:15, skampus ha scritto:
> I'm trying to dissove a shape file of polygons as results of voronoi diagram
> made by sextante mmqgisx.
> three modules are in sextante and none works
> 1) saga
> two options used (with inner boundaries and without): the boundaries still
> exist
> 2) ftools: the resulting polygon is empty
> Dissolve instance has no attribute 'myParam'
> Traceback (most recent call last):
>   File
> "C:/Users/skampus/.qgis//python/plugins\sextante\core\GeoAlgorithm.py", line
> 116, in execute
>     self.processAlgorithm(progress)
>   File "C:/Users/skampus/.qgis//python/plugins\sextante\ftools\Dissolve.py",
> line 141, in processAlgorithm
>     tempItem = atMap[ self.myParam ]
> AttributeError: Dissolve instance has no attribute 'myParam'
> 3) grass: it seems that it does the work but an error occurs at the end
> the configuration region is set as default, "use min covering region"
> activated
> 4) ftoos from vector menu: error in creating output
> 5) arcgis: it works :-(
> QGIS 1.8
> Sextante 353
> http://osgeo-org.1560.n6.nabble.com/file/n4996229/dissolve_dataset.zip
Hi all.
Any news about this?
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
