[Qgis-user] Is there smth wrong with OSGEO4W installer?
Ramon Andiñach
custard at westnet.com.au
Mon Nov 5 15:38:25 PST 2012
Downgrading the GRASS version should also restore your GRASS plugin.
On a related thought...
Until these catch up is the current situation that either QGIS works or QGIS-dev works, but not both?
-ramon.
On 06/11/2012, at 5:33, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Bernd,
> On Mon, 05. Nov 2012 at 19:06:39 +0100, Bernd Vogelgesang wrote:
>> As I described, I cleaned all visible traces of qgis, including all
>> plugins. Neverthelless, when opening an old project, qgis crashed.
>> But indeed, in some projects there were mrsid layers ...
> Reinstalling gdal-mrsid brought the problem back - not installing gdal-mrsid or
> downgrading GDAL to 1.9.1 will cure the crash.
> So until gdal-ecw is rebuilt, that's the only way to get mrsid support working.
>>> The grass plugin for 1.8 needs a rebuild too - after the upgrade to 6.4.3RC1
>>> (thought I wait until the RC vanishes...)
>> does that mean, that i have to pick another grass version to have the plugin
>> available? which will do? other things to change?
> Yes, downgrading to GRASS 6.4.2 should have worked. But there's a fresh 1.8.0(-4)
> build now anyway (but that doesn't help with the gdal-mrsid issue).
>> and i believe most people have really no clue what to do (even less than me)
>> is not everybody, installing a fresh osgeo4w setup and everyone doing an
>> update, affected by these incompatibilities, or is it just me?
> No. That should affect everyone trying to use GRASS from QGIS and/or mrsid with
> GDAL.
>>> qgis-dev should already work.
>> additionally installed dev: no grass there wouldn't be so grave, if i only
>> had the slightest idea how to work with grass from within grass ;)
> Appears to work fine here. But I still don't use it. ;)
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
