[Qgis-user] Is there smth wrong with OSGEO4W installer?
Ramon Andiñach custard at westnet.com.au
Mon Nov 5 16:51:36 PST 2012
Ok spoke too soon.
Both QGIS and -dev work together as of last nights updates.
Just getting the crash error, as some of the gdal-* libraries I have need of are a bit behind.
-ramon.
On 06/11/2012, at 7:38, Ramon Andiñach <custard at westnet.com.au> wrote:
> Downgrading the GRASS version should also restore your GRASS plugin.
> On a related thought...
> Until these catch up is the current situation that either QGIS works or QGIS-dev works, but not both?
> -ramon.
> On 06/11/2012, at 5:33, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Bernd,
>> On Mon, 05. Nov 2012 at 19:06:39 +0100, Bernd Vogelgesang wrote:
>>> As I described, I cleaned all visible traces of qgis, including all
>>> plugins. Neverthelless, when opening an old project, qgis crashed.
>>> But indeed, in some projects there were mrsid layers ...
>> Reinstalling gdal-mrsid brought the problem back - not installing gdal-mrsid or
>> downgrading GDAL to 1.9.1 will cure the crash.
>> So until gdal-ecw is rebuilt, that's the only way to get mrsid support working.
>>>> The grass plugin for 1.8 needs a rebuild too - after the upgrade to 6.4.3RC1
>>>> (thought I wait until the RC vanishes...)
>>> does that mean, that i have to pick another grass version to have the  plugin
>>> available? which will do? other things to change?
>> Yes, downgrading to GRASS 6.4.2 should have worked.   But there's a fresh 1.8.0(-4)
>> build now anyway (but that doesn't help with the gdal-mrsid issue).
>>> and i believe most people have really no clue what to do (even less than me)
>>> is not everybody, installing a fresh osgeo4w setup and everyone doing an
>>> update, affected by these incompatibilities, or is it just me?
>> No. That should affect everyone trying to use GRASS from QGIS and/or mrsid with
>> GDAL.
>>>> qgis-dev should already work.
>>> additionally installed dev: no grass there wouldn't be so grave, if i only
>>> had the slightest idea how to work with grass from within grass ;)
>> Appears to work fine here.  But I still don't use it. ;)
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>> Software Engineer         D-26506 Norden               http://www.norbit.de
>> committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
