[Qgis-user] Categorized labels
Paulo van Breugel p.vanbreugel at gmail.com
Tue Nov 6 10:58:00 PST 2012
Not exactly, but close. If you open the labeling tool, go to 'Data defined
settings' tab. There you can define font, color, etc based on user-defined
fields. But those fields must contain a color definition (RGB code I guess,
but check), numbers if you want to use it to define the font size, etc. So
I don't think you can define both color and font of a label in one column.
On Tue, Nov 6, 2012 at 5:07 PM, Piotr Pachół <piotrpachol at gmail.com> wrote:
> Hello,
> Is it possible in Qgis to display categorized labels ?
> For instance I would like to display labels from field "number" but color
> and font of label should be dependent from field "type".
> Regards,
> Piotr
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121106/90779046/attachment.html>
