[Qgis-user] Problem installing Profile plugin
Etienne Tourigny etourigny.dev at gmail.com
Tue Nov 6 13:18:32 PST 2012
uhhhhhhhhhh ...
please, what is you matplotlib version?
thanks
Etienne
On Tue, Nov 6, 2012 at 7:03 PM, JD Lancaster <jllancast at gmail.com> wrote:
>> Hi,
>> sorry for the delay... I have just uploaded version 0.5.0
>> (profiletool) which fixes this issue, as well as 1.9 compatibility and
>> other UI fixes.
>> You need to enable Experimental plugins to get this new version -
>> please test it and give me your feedback.
>> Regards,
>> Etuenne
> Hi there,
> I installed, ran, and received the following error (MACOSX 10.6.8, QGIS
> 1.8.0):
> An error has occured while executing Python code:
> Traceback (most recent call last):
>   File
> "/Users/jdlancaster/.qgis//python/plugins/profiletool/profileplugin.py",
> line 278, in changePlotLibrary
>     self.wdg.addPlotWidget(self.plotlibrary)
>   File
> "/Users/jdlancaster/.qgis//python/plugins/profiletool/ui/ui_ptdockwidget.py",
> line 143, in addPlotWidget
>     self.plotWdg = PlottingTool().changePlotWidget("Matplotlib",
> self.frame_for_plot)
>   File
> "/Users/jdlancaster/.qgis//python/plugins/profiletool/tools/plottingtool.py",
> line 82, in changePlotWidget
>     fig = Figure( (1.0, 1.0), linewidth=0.0, subplotpars =
> figure.SubplotParams(left=0, bottom=0, right=1, top=1, wspace=0, hspace=0) )
> NameError: global name 'figure' is not defined
> Python version:
> 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
> QGIS version:
> 1.8.0-Lisboa Lisboa,
> Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> '/Users/jdlancaster/.qgis//python',
> '/Users/jdlancaster/.qgis//python/plugins',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.7',
> '/Library/Python/2.7/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.7/site-packages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> '/Library/Python/2.7/site-packages',
> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools',
> '/Users/jdlancaster/Desktop']
> Qgis-user mailing list
