[Qgis-user] Problem installing Profile plugin
JLancaster jllancast at gmail.com
Tue Nov 6 13:23:38 PST 2012
matplotlib 1.1.1. I used the Kyngchaos installer.
Thanks for your work on this. An essential tool for my work.
JD
Etienne Tourigny-3 wrote
> uhhhhhhhhhh ...
> please, what is you matplotlib version?
> thanks
> Etienne
> On Tue, Nov 6, 2012 at 7:03 PM, JD Lancaster <
> jllancast@
> > wrote:
>>> Hi,
>>> sorry for the delay... I have just uploaded version 0.5.0
>>> (profiletool) which fixes this issue, as well as 1.9 compatibility and
>>> other UI fixes.
>>> You need to enable Experimental plugins to get this new version -
>>> please test it and give me your feedback.
>>> Regards,
>>> Etuenne
>> Hi there,
>> I installed, ran, and received the following error (MACOSX 10.6.8, QGIS
>> 1.8.0):
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>>   File
>> "/Users/jdlancaster/.qgis//python/plugins/profiletool/profileplugin.py",
>> line 278, in changePlotLibrary
>>     self.wdg.addPlotWidget(self.plotlibrary)
>>   File
>> "/Users/jdlancaster/.qgis//python/plugins/profiletool/ui/ui_ptdockwidget.py",
>> line 143, in addPlotWidget
>>     self.plotWdg = PlottingTool().changePlotWidget("Matplotlib",
>> self.frame_for_plot)
>>   File
>> "/Users/jdlancaster/.qgis//python/plugins/profiletool/tools/plottingtool.py",
>> line 82, in changePlotWidget
>>     fig = Figure( (1.0, 1.0), linewidth=0.0, subplotpars =
>> figure.SubplotParams(left=0, bottom=0, right=1, top=1, wspace=0,
>> hspace=0) )
>> NameError: global name 'figure' is not defined
>> Python version:
>> 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
>> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
>> QGIS version:
>> 1.8.0-Lisboa Lisboa,
>> Python path:
>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>> '/Users/jdlancaster/.qgis//python',
>> '/Users/jdlancaster/.qgis//python/plugins',
>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>> '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.7',
>> '/Library/Python/2.7/site-packages/numpy-override',
>> '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.7/site-packages',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>> '/Library/Python/2.7/site-packages',
>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools',
>> '/Users/jdlancaster/Desktop']
>> Qgis-user mailing list
> Qgis-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-installing-Profile-plugin-tp5007211p5014391.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
