[Qgis-user] Problem installing Profile plugin
Pedro Venâncio pedrongvenancio at yahoo.com
Sun Nov 11 13:54:43 PST 2012
Hi Etienne,
I'm also having some problems with the Profile Plugin. I'm using Linux (Xubuntu) and QGIS master.
The first problem is this with matplotlib (I'm also using matplotlib 1.1.1~rc1):
  File "/home/pedro/.qgis//python/plugins/profiletool/profileplugin.py", line 278, in changePlotLibrary
    self.wdg.addPlotWidget(self.plotlibrary)
  File "/home/pedro/.qgis//python/plugins/profiletool/ui/ui_ptdockwidget.py", line 143, in addPlotWidget
    self.plotWdg = PlottingTool().changePlotWidget("Matplotlib", self.frame_for_plot)
  File "/home/pedro/.qgis//python/plugins/profiletool/tools/plottingtool.py", line 82, in changePlotWidget
    fig = Figure( (1.0, 1.0), linewidth=0.0, subplotpars = figure.SubplotParams(left=0, bottom=0, right=1, top=1, wspace=0, hspace=0) )
NameError: global name 'figure' is not defined
Using Qwt5 it works, but with some problems.
On one hand, if I close the Profile Plugin before closing QGIS, the button in Plugins toolbar remains "clicked", and when closing QGIS, it shows this error:
Error while unloading plugin profiletool
  File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 237, in unloadPlugin
    plugins[packageName].unload()
  File "/home/pedro/.qgis//python/plugins/profiletool/profileplugin.py", line 80, in unload
    self.wdg.close()
RuntimeError: underlying C/C++ object has been deleted
In use, the Plugin displays a strange behavior.
Using the Selection "Temporary polyline" option, everything works fine.
However, with the Selection "Selected polyline" option, if the polyline has only 2 points (start and end), it does not create the profile. If I add another point, the Plugin only creates the profile for the first segment. If I create a fourth point, it just creates a profile for the first and second segments. And so on.
I leave a screencast showing these problems: http://goo.gl/0tMwk
Thanks!
Best regards,
Pedro Venâncio
----- Original Message -----
matplotlib 1.1.1. I used the Kyngchaos installer.
Thanks for your work on this. An essential tool for my work.
JD
Etienne Tourigny-3 wrote
> uhhhhhhhhhh ...
> please, what is you matplotlib version?
> thanks
> Etienne
> On Tue, Nov 6, 2012 at 7:03 PM, JD Lancaster <
> jllancast@
> > wrote:
>>> Hi,
>>> sorry for the delay... I have just uploaded version 0.5.0
>>> (profiletool) which fixes this issue, as well as 1.9 compatibility and
>>> other UI fixes.
>>> You need to enable Experimental plugins to get this new version -
>>> please test it and give me your feedback.
>>> Regards,
>>> Etuenne
http://lists.osgeo.org/mailman/listinfo/qgis-user
