[Qgis-user] Problem installing Profile plugin
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 12 09:32:20 PST 2012
On Sun, Nov 11, 2012 at 7:54 PM, Pedro VenĂ¢ncio
<pedrongvenancio at yahoo.com> wrote:
> Hi Etienne,
> I'm also having some problems with the Profile Plugin. I'm using Linux (Xubuntu) and QGIS master.
> The first problem is this with matplotlib (I'm also using matplotlib 1.1.1~rc1):
> Traceback (most recent call last):
> File "/home/pedro/.qgis//python/plugins/profiletool/profileplugin.py", line 278, in changePlotLibrary
> self.wdg.addPlotWidget(self.plotlibrary)
> File "/home/pedro/.qgis//python/plugins/profiletool/ui/ui_ptdockwidget.py", line 143, in addPlotWidget
> self.plotWdg = PlottingTool().changePlotWidget("Matplotlib", self.frame_for_plot)
> File "/home/pedro/.qgis//python/plugins/profiletool/tools/plottingtool.py", line 82, in changePlotWidget
> fig = Figure( (1.0, 1.0), linewidth=0.0, subplotpars = figure.SubplotParams(left=0, bottom=0, right=1, top=1, wspace=0, hspace=0) )
> NameError: global name 'figure' is not defined
I think this is due to major differences between 1.0 and 1.1 - I'll
try to look into this and probably just disable the matplotlib version
unless it's 1.0.
Unless someone has a fix for this...
> Using Qwt5 it works, but with some problems.
> On one hand, if I close the Profile Plugin before closing QGIS, the button in Plugins toolbar remains "clicked", and when closing QGIS, it shows this error:
> Error while unloading plugin profiletool
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 237, in unloadPlugin
> plugins[packageName].unload()
> File "/home/pedro/.qgis//python/plugins/profiletool/profileplugin.py", line 80, in unload
> self.wdg.close()
> RuntimeError: underlying C/C++ object has been deleted
probably a problem in plugin unloading. Please file a bug report.
> In use, the Plugin displays a strange behavior.
> Using the Selection "Temporary polyline" option, everything works fine.
> However, with the Selection "Selected polyline" option, if the polyline has only 2 points (start and end), it does not create the profile. If I add another point, the Plugin only creates the profile for the first segment. If I create a fourth point, it just creates a profile for the first and second segments. And so on.
Does this happen just with a 2-point polyline (when initially
created)? How about if you first create (and save) a 3-point polyline
before using the plugin?
Please file another bug report for this issue.
> I leave a screencast showing these problems: http://goo.gl/0tMwk
> Thanks!
> Best regards,
> Pedro VenĂ¢ncio
> ----- Original Message -----
> From: JLancaster
> matplotlib 1.1.1. I used the Kyngchaos installer.
> Thanks for your work on this. An essential tool for my work.
> JD
> Etienne Tourigny-3 wrote
>> uhhhhhhhhhh ...
>> please, what is you matplotlib version?
>> thanks
>> Etienne
>> On Tue, Nov 6, 2012 at 7:03 PM, JD Lancaster <
>> jllancast@
>> > wrote:
>>>> Hi,
>>>> sorry for the delay... I have just uploaded version 0.5.0
>>>> (profiletool) which fixes this issue, as well as 1.9 compatibility and
>>>> other UI fixes.
>>>> You need to enable Experimental plugins to get this new version -
>>>> please test it and give me your feedback.
>>>> Regards,
>>>> Etuenne
