[Qgis-user] How to open ESRI geodatabase in QGIS 1.8 and Gdal 1.9 on Ubuntu?
Johan Nilsson joni8135 at gmail.com
Wed Nov 7 10:57:01 PST 2012
Thanx :) Are a big help :) Just checked that I have minimun requements of
the gcc compiler :) Now will I see where my GDAL folder are...or just
uninstall it from synaptic? Have I understand i right, that the GDAL-bin
don't have the ability to add drivers, and that is why I need to compile a
new GDAL-bin?
/Cheers
2012/11/7 Alex Mandel <tech_dev at wildintellect.com>
> Looking at the gdal-build-mrsid helper tool, I think the pattern is:
> 1. download the SDK from ESRI
> 2. build a copy of gdal (same version you have on your system already)
> off to the side with the FGDB plugin enabled
> 3. Install/Copy that plugin into your ogr (gdal?) plugins folder
> I'm still digging to see if someone has written out a helper script or
> more clear instructions.
> Enjoy,
> Alex
> On 11/07/2012 09:47 AM, Johan Nilsson wrote:
> > Peter. I think Add-vector-->Database-->ESRI personal geodatabase, are
> just
> > Personal Geodatabase, aka a JET-db or MS-access-database? ESRIs File
> > database are what ESRI recommend to use, not the MS-Access typ of db
> > because of bad preformance add a size limit of 1GB.
> > I stilll try to understand what I need to do with GDAL and the
> > ESRI-FileGDB... I need to uninstall the old GDAL things and stuff? Don't
> > what to break the system...
> > Cheers
> > 2012/11/7 Peter Schürch <p.schuerch at meierpartner.ch>
> >> I think I managed to open ESRI Geodatabase as a Database source without
> >> any tweaking opening them as a Vectorfile and then choosing Database
> >> (instead of File).****
> >> Peter ****
> >> QGis 1.8, Windows 7****
> >> Meier und Partner AG, Switzerland, www.meierpartner.ch****
> >> *Von:* qgis-user-bounces at lists.osgeo.org [mailto:
> >> qgis-user-bounces at lists.osgeo.org] *Im Auftrag von *Johan Nilsson
> >> *Gesendet:* Mittwoch, 7. November 2012 13:07
> >> *An:* qgis-user
> >> *Betreff:* Re: [Qgis-user] How to open ESRI geodatabase in QGIS 1.8 and
> >> Gdal 1.9 on Ubuntu?****
> >> Thanx. Downloadig the FileGDB_API_1_2-32.tar.gz and also the 64-bit
> >> version.
> >> I have only compiled one thing in Ubuntu and that was a component in
> Unity
> >> (to get navigation buttom, to the left in stead of right, and during
> that I
> >> have a row, to row tutorial.
> >> Can this help me?
> >> https://github.com/usgin/ncgmp/wiki/Installation-Example
> >> Thanx for al tips and helps /Cheers****
> >> 2012/11/7 Alex Mandel <tech_dev at wildintellect.com>****
> >> On 11/06/2012 10:43 PM, Johan Nilsson wrote:
> >>> How do I open ESRIs geodatabase .gdb-files in QGIS 1.8 and Gdal 1.9? I
> >> have
> >>> found on internet that the package OSGeo4W are needed, but this is only
> >> för
> >>> ms-windows, i suppose, but I run Ubuntu 12.04LTS. As I understand it,
> is
> >>> should also only bee possible for ArcGIS 10, not older versions of
> >> ArcGIS.
> >>> By the way, .gdb appears in Ubuntu as a folder with lot of files
> inside.
> >>> /Cheers Jjohan N
> >> They can be opened on either Windows or Linux, what you need is the
> >> gdal/ogr file geodatabase driver. This requires getting some files from
> >> ESRI (free) and doing a little bit of compiling.
> >> I found this which should help. But I though there was a way that didn't
> >> require a complete gdal compile.
> >> http://www.paolocorti.net/2012/01/10/gdal_19_released/
> >> As for ArcGIS, there are several versions of Geodatabases, newer Arcs
> >> can read older databases but not vice versa.
> >> Thanks,
> >> Alex
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121107/895bde4b/attachment.html>
