[Qgis-user] Python error enabling sextante plugin
Matteo Ghetta matteo.ghetta at gmail.com
Fri Nov 9 01:49:52 PST 2012
I don't want peace, I want sextante!! :-)
Anyway, I tried to move the plugin from the core
(/usr/share/qgis/python/plugins), but running qgis it appears the python
error again.
I'd leave things the way they are and wait for next week.
2012/11/9 Andre Joost <andre+joost at nurfuerspam.de>
> Am 09.11.12 10:18, schrieb Matteo Ghetta:
>  Hi guys,
>> i have almost the same problem with sextante and python (qgis 1.9 on
>> ubuntu).
>> I started qgis as usually and qgis gave me the python error above
>> described.
>> So I tried to uninstall sextante, re-install it, and move directories
>> (from
>> /usr/share/qgis/python/plugins and from /.qgis) and replace them.
>> What now happens is that, running qgis I have this error:
>> SEXTANTE
>> The Plugin Installer has detected an obsolete plugin which masks a newer
>> version shipped with this QGIS version. This is likely due to files
>> associated with a previous installation of QGIS. Please use the Plugin
>> Installer to remove that older plugin in order to unmask the newer version
>> shipped with this copy of QGIS.
>> Sextante and qgis work without problems, but I don't understand I I should
>> do something to solve this little problem.
> Same here. You now have both versions (core and external plugin). I guess
> you have re-installed 1.07, not 1.08.
> Removing the plugin from core leaves you with the working 1.0.7 in .qgis
> and no annoying message at start.
> The other way won't work: Removing the external plugin gives you the error
> message reported before.
> Off course, removing both you have peace, but no Sextante ;-)
> I don't know about the ubuntu file structure. Maybe you have another copy
> of Sextante somewhere else.
> HTH,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121109/0a752bc0/attachment.html>
