[Qgis-user] OTB issues
Giovanni Manghi
giovanni.manghi at faunalia.pt
Sat Nov 10 13:01:46 PST 2012
> Hi Giovanni,
> Thank you for the answer, but I did the same that you are suggesting me
> and I am glad for that because I was not sure enough to do that and now
> what I have in front of me are more questions than answers. For instance
> what I am trying to do is how is shown in this link:
> http://www.youtube.com/watch?v=XcAQDFtkbdk
a few notes:
*) the folders are not correctly configured. I don't remember exactly
how the OTB ones must be configured on WIndows, but for sure the SAGA
one must point to SAGA binaries. As SAGA cannot be installed with
osgeo4w (as OTB and GRASS) you must download it separately. I would
suggest using this
http://sourceforge.net/projects/saga-gis/files/SAGA%20-%202.0/SAGA%202.0.8/saga_2.0.8_bin_msw_x64.zip/download
that doesn't require any installation at all.
*) to run the mean shift segmentation tool you must use qgis-dev (aka
master) as this OTB tool was recently moved inside another tool. This
was fixed only a few hours ago in qgis-master.
*) be sure also to have installed OTB with osgeo4w, is not installed
by default with QGIS (but GRASS is).
cheers
-- Giovanni --
> I did that steps after steps and the system returned me this message:
> Then I checked the Sextante log and I read this information:
> 1- OTB execution console output
> '"C:\Users\Owner\sextante\tempdata\\otbcli_MeanShiftSegmentation"' is not
> recognized as an internal or external command,
> operable program or batch file.
> 2- SAGA execution commands
> io_gdal 0 -GRIDS "C:\Users\Owner\sextante\tempdata\1352576101.2845.sgrd"
> -FILES "C:\Users\Owner\sextante\tempdata\modelertest139.tif"
> shapes_grid "Vectorising Grid Classes" -GRID
> "C:\Users\Owner\sextante\tempdata\1352576101.2845.sgrd" -CLASS_ALL 1
> -CLASS_ID 0 -SPLIT 1 -POLYGONS
> "C:\Users\Owner\sextante\tempdata\modelertest142.shp"
> 3- SAGA execution console output
> C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OSGeo4W\OSGeo4W>set
> SAGA=C:\Users\Owner\sextante\tempdata\
> SAGA_MLB=C:\Users\Owner\sextante\tempdata\\modules
> Menu\Programs\OSGeo4W\OSGeo4W>PATH=PATH;C:\Users\Owner\sextante\tempdata\;C:\Users\Owner\sextante\tempdata\\modules
> Menu\Programs\OSGeo4W\OSGeo4W>saga_cmd io_gdal 0 -GRIDS
> "C:\Users\Owner\sextante\tempdata\1352576101.2845.sgrd" -FILES
> 'saga_cmd' is not recognized as an internal or external command,
> Menu\Programs\OSGeo4W\OSGeo4W>saga_cmd shapes_grid "Vectorising Grid
> Classes" -GRID "C:\Users\Owner\sextante\tempdata\1352576101.2845.sgrd"
> -CLASS_ALL 1 -CLASS_ID 0 -SPLIT 1 -POLYGONS
> C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OSGeo4W\OSGeo4W>exit
> In my opinion I should have problem with the configuration of the OTB in
> QGIS, but I do not know how to fix it.
> I will show you my Sextant options and configuration to be sure I have it
> properly. Only for clarification I did not change anything after I installed
> the QGIS:
> Any help to resolve this issue?
> Hilario
> On Sat, Nov 10, 2012 at 11:15 AM, Giovanni Manghi
> <giovanni.manghi at faunalia.pt> wrote:
>> Hi,
>> > I am new using the QGIS and now I have to prepare some backscatter
>> > imagen
>> > processing using OTB and for some reason when I installed the QGIS I
>> > am
>> > having this message of error.
>> > [image: Inline image 1]
>> > Can I have some help, I am trying to this this for more than 3 days
>> > without
>> > success.
>> you have to do what is written in the error message, check the
>> sextante log (look in the "analysis" menu, "log" entry) to understand
>> what is going on. Probably you haven't configured properly the
>> sextante folders (again, look in the "configuration" in the analysis
>> menu).
>> I would suggest also to try qgis master with osgeo4w, it has the
>> latest Sextante features/fixes.
>> Cheers
>> -- Giovanni --
