[Qgis-user] Problem to create gdalindex - other projection-system
Jan Tappenbeck osm at tappenbeck.net
Mon Nov 12 07:04:14 PST 2012
hi !
i had to create a image-cataog by using the gdalindex-command
after using the command i get following message:
Warning : xxxx/BP_030.TIF is not using the same projection system as
other files in the tileindex. This may cause problems when using it in
MapServer for example.
Warning : xxxx/BP_166.TIF is not using the same projection system as
the problem - this image and the wordfiles where create manuell. did
anyone know a special way or a possibility to add the projection-system
manuell to the images.
regards Jan
---- here are the image informations ----
***** BP_030.TIF*****
Driver: GTiff/GeoTIFF
Files: XXXX/BP_030.TIF
        XXXX/BP_030.TFw
Size is 2645, 3326
Coordinate System is `'
Origin = (2569667.718310019000000,5673146.381686710800000)
Pixel Size = (0.063379962192866,-0.063373421527158)
Metadata:
   TIFFTAG_SOFTWARE=IrfanView
   TIFFTAG_XRESOLUTION=200
   TIFFTAG_YRESOLUTION=200
   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
   COMPRESSION=PACKBITS
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 2569667.718, 5673146.382)
Lower Left  ( 2569667.718, 5672935.602)
Upper Right ( 2569835.358, 5673146.382)
Lower Right ( 2569835.358, 5672935.602)
Center      ( 2569751.538, 5673040.992)
Band 1 Block=2645x3 Type=Byte, ColorInterp=Palette
   Color Table (RGB with 256 entries)
     0: 0,0,0,255
     1: 255,255,255,255
   255: 255,255,255,255
**** other Image ****
Files: XXXXX/BP_030 (2).TIF
Size is 2778, 3431
Coordinate System is:
PROJCS["ETRS89 / UTM zone 32N",
     GEOGCS["ETRS89",
         DATUM["European_Terrestrial_Reference_System_1989",
             SPHEROID["GRS 1980",6378137,298.2572221010002,
                 AUTHORITY["EPSG","7019"]],
             AUTHORITY["EPSG","6258"]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433],
         AUTHORITY["EPSG","4258"]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",9],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","25832"]]
Origin = (359942.545087174860000,5672753.619195298300000)
Pixel Size = (0.063364269888320,-0.063364269888320)
Metadata:
   AREA_OR_POINT=Area
   COMPRESSION=LZW
   INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  359942.545, 5672753.619) (  6d59'44.79"E, 51d11'20.46"N)
Lower Left  (  359942.545, 5672536.216) (  6d59'45.09"E, 51d11'13.42"N)
Upper Right (  360118.571, 5672753.619) (  6d59'53.85"E, 51d11'20.61"N)
Lower Right (  360118.571, 5672536.216) (  6d59'54.15"E, 51d11'13.58"N)
Center      (  360030.558, 5672644.918) (  6d59'49.47"E, 51d11'17.02"N)
Band 1 Block=2778x1 Type=Byte, ColorInterp=Red
   Overviews: 1389x1716, 695x858, 348x429, 174x215, 87x108, 44x54, 22x27
   Mask Flags: PER_DATASET ALPHA
   Overviews of mask band: 1389x1716, 695x858, 348x429, 174x215, 87x108,
44x54, 22x27
Band 2 Block=2778x1 Type=Byte, ColorInterp=Green
44x54, 22x27
Band 3 Block=2778x1 Type=Byte, ColorInterp=Blue
44x54, 22x27
Band 4 Block=2778x1 Type=Byte, ColorInterp=Alpha
