[Qgis-user] Problem to create gdalindex - other projection-system
Andre Joost andre+joost at nurfuerspam.de
Mon Nov 12 07:13:59 PST 2012
Hi Jan,
Am 12.11.2012 16:04, schrieb Jan Tappenbeck:
> hi !
> i had to create a image-cataog by using the gdalindex-command
> after using the command i get following message:
> Warning : xxxx/BP_030.TIF is not using the same projection system as
> other files in the tileindex. This may cause problems when using it in
> MapServer for example.
> ---- here are the image informations ----
> ***** BP_030.TIF*****
> Driver: GTiff/GeoTIFF
> Files: XXXX/BP_030.TIF
> XXXX/BP_030.TFw
> Size is 2645, 3326
> Coordinate System is `'
This is breaking. You have to set a Coordinate system for the tif.
Should be the same as the others. In Qgis,
Ratser->Projektionen->Projektion zuweisen will do.
