[Qgis-user] qgis and Large Format Print
G. Allegri giohappy at gmail.com
Wed Nov 14 07:51:09 PST 2012
Are you using qgis from trunk or qgis 1.8?
giovanni
2012/11/14 Andrea Peri <aperi2007 at gmail.com>
> Hi,
> When try to plot or export on a pdf an A0 format using the composer.
> I see sometime the qgis crash.
> I need to print in A0 few times and so when qgis crash, I simply
> reduce the quality from 600 dpi to 300 dpi and all go ok.
> However I like to understand why qgis crash.
> Infact I read somewhere that it is a memory availability problem.
> So I like to know if increasing my memory RAM this crash problem could
> disappeared.
> Also I need to understand if a 4GB ram that is the maximum ram usable
> on my window 32 bit.
> Could be sufficient for a A0 print.
> Thx,
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121114/7c1e10e5/attachment.html>
