[Qgis-user] qgis and Large Format Print
Andrea Peri
aperi2007 at gmail.com
Wed Nov 14 08:30:52 PST 2012
Both.
Usually I try to print firstly with 1.8.0.
If it crash , then I try with qgis trunk.
Sometime trunk has successful some other time no.
2012/11/14 G. Allegri <giohappy at gmail.com>:
> Are you using qgis from trunk or qgis 1.8?
> giovanni
> 2012/11/14 Andrea Peri <aperi2007 at gmail.com>
>> Hi,
>> When try to plot or export on a pdf an A0 format using the composer.
>> I see sometime the qgis crash.
>> I need to print in A0 few times and so when qgis crash, I simply
>> reduce the quality from 600 dpi to 300 dpi and all go ok.
>> However I like to understand why qgis crash.
>> Infact I read somewhere that it is a memory availability problem.
>> So I like to know if increasing my memory RAM this crash problem could
>> disappeared.
>> Also I need to understand if a 4GB ram that is the maximum ram usable
>> on my window 32 bit.
>> Could be sufficient for a A0 print.
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
