[Qgis-user] qgis and Large Format Print
G. Allegri giohappy at gmail.com
Wed Nov 14 13:13:25 PST 2012
Could you share a sample project. I suppose you're using the Regione
Toscana WMS...
2012/11/14 Andrea Peri <aperi2007 at gmail.com>
> My print A0 are always with a base map of ortofoto from WMS (using tile
> option).
> When try with 1.8.0 is will crash with a messagebox.
> Using the trunk version sometime the print process will stop without
> inish the download of all tiles.
> I guess this is a silent crash of the printer module or of the composer.
> 2012/11/14 G. Allegri <giohappy at gmail.com>:
> > I just asked because I haven't noticed the A0 issue with the trunk...
> > giovanni
> >> Both.
> >> Usually I try to print firstly with 1.8.0.
> >> If it crash , then I try with qgis trunk.
> >> Sometime trunk has successful some other time no.
> >> > Are you using qgis from trunk or qgis 1.8?
> >> > giovanni
> >> >> Hi,
> >> >> When try to plot or export on a pdf an A0 format using the composer.
> >> >> I see sometime the qgis crash.
> >> >> I need to print in A0 few times and so when qgis crash, I simply
> >> >> reduce the quality from 600 dpi to 300 dpi and all go ok.
> >> >> However I like to understand why qgis crash.
> >> >> Infact I read somewhere that it is a memory availability problem.
> >> >> So I like to know if increasing my memory RAM this crash problem
> could
> >> >> disappeared.
> >> >> Also I need to understand if a 4GB ram that is the maximum ram usable
> >> >> on my window 32 bit.
> >> >> Could be sufficient for a A0 print.
> >> >> Thx,
> >> >> Andrea Peri
> >> >> qwerty àèìòù
> >> >> _______________________________________________
> >> >> Qgis-user mailing list
> >> >> Qgis-user at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Andrea Peri
> >> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121114/6a705a5c/attachment.html>
