[Qgis-user] qgis and Large Format Print
Andrea Peri aperi2007 at gmail.com
Wed Nov 14 14:05:33 PST 2012
No problema, but
AFAIK the qgis problem don't save the print composer.
so it should always be recreate.
The project is only a layer or two from the RT-WMS.
2012/11/14 G. Allegri <giohappy at gmail.com>:
> Could you share a sample project. I suppose you're using the Regione Toscana
> WMS...
> 2012/11/14 Andrea Peri <aperi2007 at gmail.com>
>> My print A0 are always with a base map of ortofoto from WMS (using tile
>> option).
>> When try with 1.8.0 is will crash with a messagebox.
>> Using the trunk version sometime the print process will stop without
>> inish the download of all tiles.
>> I guess this is a silent crash of the printer module or of the composer.
>> > I just asked because I haven't noticed the A0 issue with the trunk...
>> > giovanni
>> >> Both.
>> >> Usually I try to print firstly with 1.8.0.
>> >> If it crash , then I try with qgis trunk.
>> >> Sometime trunk has successful some other time no.
>> >> > Are you using qgis from trunk or qgis 1.8?
>> >> > giovanni
>> >> >> Hi,
>> >> >> When try to plot or export on a pdf an A0 format using the composer.
>> >> >> I see sometime the qgis crash.
>> >> >> I need to print in A0 few times and so when qgis crash, I simply
>> >> >> reduce the quality from 600 dpi to 300 dpi and all go ok.
>> >> >> However I like to understand why qgis crash.
>> >> >> Infact I read somewhere that it is a memory availability problem.
>> >> >> So I like to know if increasing my memory RAM this crash problem
>> >> >> could
>> >> >> disappeared.
>> >> >> Also I need to understand if a 4GB ram that is the maximum ram
>> >> >> usable
>> >> >> on my window 32 bit.
>> >> >> Could be sufficient for a A0 print.
>> >> >> Thx,
>> >> >> Andrea Peri
>> >> >> qwerty àèìòù
>> >> >> _______________________________________________
>> >> >> Qgis-user mailing list
>> >> >> Qgis-user at lists.osgeo.org
>> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Andrea Peri
>> >> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
