[Qgis-user] qgis and Large Format Print
G. Allegri
giohappy at gmail.com
Wed Nov 14 14:38:00 PST 2012
> AFAIK the qgis problem don't save the print composer.
> so it should always be recreate.
??? It should. It's also used by qgis server to provide print capabilities.
Anyway, I'll test it with any RT-WMS, ASAP
> The project is only a layer or two from the RT-WMS.
> 2012/11/14 G. Allegri <giohappy at gmail.com>:
> > Could you share a sample project. I suppose you're using the Regione
> Toscana
> > WMS...
> > 2012/11/14 Andrea Peri <aperi2007 at gmail.com>
> >> My print A0 are always with a base map of ortofoto from WMS (using tile
> >> option).
> >> When try with 1.8.0 is will crash with a messagebox.
> >> Using the trunk version sometime the print process will stop without
> >> inish the download of all tiles.
> >> I guess this is a silent crash of the printer module or of the composer.
> >> > I just asked because I haven't noticed the A0 issue with the trunk...
> >> > giovanni
> >> >> Both.
> >> >> Usually I try to print firstly with 1.8.0.
> >> >> If it crash , then I try with qgis trunk.
> >> >> Sometime trunk has successful some other time no.
> >> >> > Are you using qgis from trunk or qgis 1.8?
> >> >> > giovanni
> >> >> >> Hi,
> >> >> >> When try to plot or export on a pdf an A0 format using the
> composer.
> >> >> >> I see sometime the qgis crash.
> >> >> >> I need to print in A0 few times and so when qgis crash, I simply
> >> >> >> reduce the quality from 600 dpi to 300 dpi and all go ok.
> >> >> >> However I like to understand why qgis crash.
> >> >> >> Infact I read somewhere that it is a memory availability problem.
> >> >> >> So I like to know if increasing my memory RAM this crash problem
> >> >> >> could
> >> >> >> disappeared.
> >> >> >> Also I need to understand if a 4GB ram that is the maximum ram
> >> >> >> usable
> >> >> >> on my window 32 bit.
> >> >> >> Could be sufficient for a A0 print.
> >> >> >> Thx,
> >> >> >> Andrea Peri
> >> >> >> qwerty àèìòù
> >> >> >> _______________________________________________
> >> >> >> Qgis-user mailing list
> >> >> >> Qgis-user at lists.osgeo.org
> >> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> >> Andrea Peri
> >> >> qwerty àèìòù
> >> Andrea Peri
> >> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121114/1c0ed8eb/attachment.html>
