[Qgis-user] How to compile gdal with ESRI FileGDB
Johan Nilsson joni8135 at gmail.com
Thu Nov 15 01:14:16 PST 2012
Thanks very much Eric :)
I have read the instuctions, and
tar zxvf FileGDB_API_1_2-32.tar.gz went well but I'm stuck on point 4 in
the fist part of you instruction to make a sample to test the driver:
~/Desktop/gdal-mod/FileGDB_API/samples$ make
It spot out a lot of thing complaining about 'undefiened reference to'...
and it ends like:
../../lib/libFileGDBAPI.so: undefined reference to `PathFileExistsW(wchar_t
const*)'
`PathFindExtensionW(wchar_t const*)'
collect2: ld returned 1 exit status
make[1]: *** [../bin/Domains] Error 1
make[1]: Leaving directory
`/home/a/Desktop/gdal-mod/FileGDB_API/samples/Domains'
make: *** [Domains] Error 2
Joni at Intel:~/Desktop/gdal-mod/FileGDB_API/samples$
I tried to ignore the errors above, but when I move to *bin* it was empty
and nothing happend:
~/Desktop/gdal-mod/FileGDB_API/samples/bin$ ./Querying
bash: ./Querying: No such file or directory
I checked with ls -all and *bin* was empty.
Cheers and thanks
/Johan
2012/11/14 Eric Goddard <egoddard1010 at gmail.com>
> Below are the steps I use to add File Geodatabase support to gdal. This
> worked on Ubuntu 12.04 64-bit, but it doesn't use the deb source packages.
> Since you have a 32-bit ubuntu install, you need to download the 32-bit
> version of the FileGDB API. I tried to answer your questions as they come
> up in the steps I list below, so you may want to read through the whole
> thing before starting. Sorry for the length, but I hope it helps!
> In terminal:
> 1. Change directory to wherever you downloaded the FileGDBAPI: *cd
> path/to/FileGDBAPI_download*
> 2. extract the archive:* tar zxvf FileGDB_API_1_2-32.tar.gz* NOTE: Since
> you are using 32-bit Ubuntu, you need to download the 32-bit FileGDB API.
> 3.You need to build the samples to make sure the API works. Change to the
> FileGDB_API samples folder: *cd FileGDB_API/samples*
> 4. type *make*
> 5. Run a sample to make sure it works. Change directory to the bin folder
> inside samples: *cd bin *, and then type *./Querying*. You'll get a bunch
> of text in terminal, just make sure it doesn't spit out any errors.
> 6. If the sample runs successfully, you have a working FileGDB API and you
> are ready to compile GDAL. I like to move the FileGDB API to a better
> location than the downloads directory, but it is up to you. If you choose
> to move it, you can use the paths listed below. If you use your own
> location, change the path in the commands below to whatever you used. *sudo
> mv <your location>/FileGDB_API /usr/local/*
> 7. Create a LD configuration file so that gdal is able to find the FGDB
> libraries: *sudo echo /usr/local/FileGDB_API/lib >
> etc/ld.so.conf.d/fgdb.conf *
> An explanation of ld is below.
> 8. run ldconfig to update the linked libraries: *sudo ldconfig*
> You're now ready to download and configure gdal.
> 1. Download gdal from http://download.osgeo.org/gdal/gdal-1.9.2.tar.gz
> 2. Extract the contents of the gdal archive: *tar zxvf gdal-1.9.2.tar.gz*
> 3. Change to the gdal directory: *cd gdal-1.9.2*
> 4. Now gdal needs to be configured. Your configure line may be different
> from the one below depending on the options you want included, but the
> important line to include is --with-fgdb=/usr/local/FileGDB_API. This is my
> configure line on my system: * ./configure --with-geos=yes --with-sqlite3
> --with-python --with-spatialite --with-fgdb=/usr/local/FileGDB_API
> --with-postgres --with-odbc --with-libkml=yes --with-curl=yes
> --with-mrsid=/usr/local/MrSID_SDK/Raster_DSDK
> --with-mrsid_lidar=/usr/local/MrSID_SDK/Lidar_DSDK
> --with-openjpeg=/usr/include*
> The --with statements let the configuration script know what additional
> modules you want to be included in the compile. When you install packages,
> such as geos, from the repos the libraries are put in paths that ld (which
> is a utility that links libraries so that other applications are able to
> find them) knows about. When you compile by hand the general practice is to
> compile to /usr/local, which sometimes ld doesn't know about by default.
> You let ld know about additional paths by creating a configuration file in
> /etc/ld.so.conf.d/ that contains the path of your custom compiled
> libraries.
> To compile GDAL with the options you want, your line might look something
> like this:
> *./configure --with-geos=yes --with-sqlite3 --with-python
> --with-spatialite --with-fgdb=/usr/local/FileGDB_API --with-postgres
> --with-odbc *
> After configure runs, it will give you a summary that indicates what it
> was able to find. Check to make sure that there is a 'yes' beside the
> options you want. If there is a no beside something you want to include,
> you may need to scroll through the output and find the error to see what
> went wrong.
> 5. Now you can run make and make install. *sudo make*. When that
> finishes, run *sudo make install*.
> 6. One more step: you need to let ld know about the gdal libraries. Since
> we didn't specify a different path, the configure line above puts them in
> /usr/local/lib by default. I let ld know about the libraries by adding a
> local.conf file to /etc/ld.so.conf.d/. *sudo echo /usr/local/lib >
> /etc/ld.so.conf.d/local.conf*
> 7. Run ldconfig again: *sudo ldconfig*
> You should be able to open geodatabases in QGIS or any other GIS
> application that uses GDAL now. I expanded on notes that I took while doing
> the install, but I didn't have my linux laptop with me while writing this.
> Let me know if anything doesn't work or if clarification is needed.
> On Nov 13, 2012 9:27 AM, "Johan Nilsson" <joni8135 at gmail.com> wrote:
>>  I have tried to find how I compile gdal 1.9.2 with ESRIs FileGDB_API,
>> but I'm are very uncertain how it work. I have Ubuntu 10.04LTS 32-bit
>> with PAE. I another step I downloaded source-code for gdal-1.9.2 and added
>> needed packed with:
>> *cd ~/Desktop/gdal-mod* <--move cursor to the created folder.
>> *apt-get source gdal-bin *<--download source-cod from my respositories
>> (same as my binary installed on my system, into the folder I stand in
>> ~/Desktop/gdal-mod)
>> *sudo apt-get build-dep gdal* <--geting dependencies so my system can
>> build the package gdal.
>>  From https://github.com/usgin/ncgmp/wiki/Installation-Example I found
>> this example
>>    1.
>>    *cd ~/downloads *<--change to the folder with the downloaded driver
>>    from ESRI*
>>    2.
>>    *tar xzf FileGDB_API_1_2-64.tar.gz *<--unpacking
>>    3.
>>    *cd ~/downloads/FileGDB_API/lib *<--goes to a file in the unpacked
>>    FileGDB*
>>    4.
>>    *ln -s libfgdbunixrtl.so libfgdblinuxrtl.so <--made a symbolic link
>>    in the folder lib because ESRI change the name.*
>>    5.
>>    *cd ../..* <--up 2 levels*
>>    6.
>>    *tar xvf gdal-1.9.0.tar.gz *<--unpacking, I have a newer file*
>>    7.
>>    *cd gdal-1.9.0 *
>>    8.
>>    *./configure --with-pg=/usr/bin/pg_config
>>    --with-fgdb=/home/ubuntu/downloads/FileGDB_API
>>    --with-geos=/usr/local/bin/geos-config
>>    --with-static-proj4=/usr/local/lib/libproj.a --with-python *
>>    9.
>>    *make *
>>    10.
>>    *sudo make install*
>> First a question! If I make a 'make install', and if it don't work, how
>> can i change back to my original gdal-bin?
>> Second. Does this install libFileGDBAPI.so (Read a tutorial, there they
>> said that libFileGDBAPI.so should be install in it default directory,
>> which I don't know where it is...
>>  6. I have a newer version of gdal (1.9.2) and I have the 32-bit version
>> on this machine. The swift '--with' in this example above are not so
>> accurate for my system, I think? What does '--with' really do? Does it
>> create links in gdal or does it more?
>> Does someone know which swift '--with ' I should have or are necessaryor good to have? Do the FileGDB also get compiled at the same time?
>> I seach my system and change the path in the example: first where I have
>> my FileGDB_API and then some other files have also a different path? Do
>> I need all this --with, or does a default file add it?
>> My modified '--with', if it's needed?
>> --with-fgdb=/home/Joni/Desktop/gdal-mod/FileGDB_API
>> --with-geos=/usr/bin/geos-config --with-static-proj4=/usr/lib/libproj.a
>> --with-python
>> If I don't add anything more than, my FilGDB_API, there the source-code
>> are, does there are any 'Default setting', so It work as now? I had a
>> Postgis config-file as in the example. In this example they had compiled
>> a geos package, but my system did have libgeos and a geos-config file in
>> above blue directory. The '*--with-static-proj4=/usr/local/lib/libproj.a*
>> *' *have I changed to another *path*, there I find a* **libproj.a** *
>> file.
>> Hope someone can explain little..
>> /Cheers
>> Johan
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121115/8a9898b2/attachment.html>
