[Qgis-user] How to compile gdal with ESRI FileGDB
Eric Goddard
egoddard1010 at gmail.com
Thu Nov 15 06:30:43 PST 2012
Hmmm, I didn't get any errors like that when I installed so I'm not sure
what could be causing it. Do you have the build-essential package installed
that provides the necessary compile tools?
On Thu, Nov 15, 2012 at 3:14 AM, Johan Nilsson <joni8135 at gmail.com> wrote:
> Thanks very much Eric :)
> I have read the instuctions, and
> tar zxvf FileGDB_API_1_2-32.tar.gz went well but I'm stuck on point 4 in
> the fist part of you instruction to make a sample to test the driver:
> ~/Desktop/gdal-mod/FileGDB_API/samples$ make
> It spot out a lot of thing complaining about 'undefiened reference to'...
> and it ends like:
> ../../lib/libFileGDBAPI.so: undefined reference to
> `PathFileExistsW(wchar_t const*)'
> `PathFindExtensionW(wchar_t const*)'
> collect2: ld returned 1 exit status
> make[1]: *** [../bin/Domains] Error 1
> make[1]: Leaving directory
> `/home/a/Desktop/gdal-mod/FileGDB_API/samples/Domains'
> make: *** [Domains] Error 2
> Joni at Intel:~/Desktop/gdal-mod/FileGDB_API/samples$
> I tried to ignore the errors above, but when I move to *bin* it was empty
> and nothing happend:
> ~/Desktop/gdal-mod/FileGDB_API/samples/bin$ ./Querying
> bash: ./Querying: No such file or directory
> I checked with ls -all and *bin* was empty.
> Cheers and thanks
> /Johan
> 2012/11/14 Eric Goddard <egoddard1010 at gmail.com>
>> Below are the steps I use to add File Geodatabase support to gdal. This
>> worked on Ubuntu 12.04 64-bit, but it doesn't use the deb source packages.
>> Since you have a 32-bit ubuntu install, you need to download the 32-bit
>> version of the FileGDB API. I tried to answer your questions as they come
>> up in the steps I list below, so you may want to read through the whole
>> thing before starting. Sorry for the length, but I hope it helps!
>> In terminal:
>> 1. Change directory to wherever you downloaded the FileGDBAPI: *cd
>> path/to/FileGDBAPI_download*
>> 2. extract the archive:* tar zxvf FileGDB_API_1_2-32.tar.gz* NOTE: Since
>> you are using 32-bit Ubuntu, you need to download the 32-bit FileGDB API.
>> 3.You need to build the samples to make sure the API works. Change to the
>> FileGDB_API samples folder: *cd FileGDB_API/samples*
>> 4. type *make*
>> 5. Run a sample to make sure it works. Change directory to the bin folder
>> inside samples: *cd bin *, and then type *./Querying*. You'll get a
>> bunch of text in terminal, just make sure it doesn't spit out any errors.
>> 6. If the sample runs successfully, you have a working FileGDB API and
>> you are ready to compile GDAL. I like to move the FileGDB API to a better
>> location than the downloads directory, but it is up to you. If you choose
>> to move it, you can use the paths listed below. If you use your own
>> location, change the path in the commands below to whatever you used. *sudo
>> mv <your location>/FileGDB_API /usr/local/*
>> 7. Create a LD configuration file so that gdal is able to find the FGDB
>> libraries: *sudo echo /usr/local/FileGDB_API/lib >
>> etc/ld.so.conf.d/fgdb.conf *
>> An explanation of ld is below.
>> 8. run ldconfig to update the linked libraries: *sudo ldconfig*
>> You're now ready to download and configure gdal.
>> 1. Download gdal from http://download.osgeo.org/gdal/gdal-1.9.2.tar.gz
>> 2. Extract the contents of the gdal archive: *tar zxvf gdal-1.9.2.tar.gz*
>> 3. Change to the gdal directory: *cd gdal-1.9.2*
>> 4. Now gdal needs to be configured. Your configure line may be different
>> from the one below depending on the options you want included, but the
>> important line to include is --with-fgdb=/usr/local/FileGDB_API. This is my
>> configure line on my system: * ./configure --with-geos=yes
>> --with-sqlite3 --with-python --with-spatialite
>> --with-fgdb=/usr/local/FileGDB_API --with-postgres --with-odbc
>> --with-libkml=yes --with-curl=yes
>> --with-mrsid=/usr/local/MrSID_SDK/Raster_DSDK
>> --with-mrsid_lidar=/usr/local/MrSID_SDK/Lidar_DSDK
>> --with-openjpeg=/usr/include*
>> The --with statements let the configuration script know what additional
>> modules you want to be included in the compile. When you install packages,
>> such as geos, from the repos the libraries are put in paths that ld (which
>> is a utility that links libraries so that other applications are able to
>> find them) knows about. When you compile by hand the general practice is to
>> compile to /usr/local, which sometimes ld doesn't know about by default.
>> You let ld know about additional paths by creating a configuration file in
>> /etc/ld.so.conf.d/ that contains the path of your custom compiled
>> libraries.
>> To compile GDAL with the options you want, your line might look something
>> like this:
>> *./configure --with-geos=yes --with-sqlite3 --with-python
>> --with-spatialite --with-fgdb=/usr/local/FileGDB_API --with-postgres
>> --with-odbc *
>> After configure runs, it will give you a summary that indicates what it
>> was able to find. Check to make sure that there is a 'yes' beside the
>> options you want. If there is a no beside something you want to include,
>> you may need to scroll through the output and find the error to see what
>> went wrong.
>> 5. Now you can run make and make install. *sudo make*. When that
>> finishes, run *sudo make install*.
>> 6. One more step: you need to let ld know about the gdal libraries. Since
>> we didn't specify a different path, the configure line above puts them in
>> /usr/local/lib by default. I let ld know about the libraries by adding a
>> local.conf file to /etc/ld.so.conf.d/. *sudo echo /usr/local/lib >
>> /etc/ld.so.conf.d/local.conf*
>> 7. Run ldconfig again: *sudo ldconfig*
>> You should be able to open geodatabases in QGIS or any other GIS
>> application that uses GDAL now. I expanded on notes that I took while doing
>> the install, but I didn't have my linux laptop with me while writing this.
>> Let me know if anything doesn't work or if clarification is needed.
>> On Nov 13, 2012 9:27 AM, "Johan Nilsson" <joni8135 at gmail.com> wrote:
>>> I have tried to find how I compile gdal 1.9.2 with ESRIs FileGDB_API,
>>> but I'm are very uncertain how it work. I have Ubuntu 10.04LTS 32-bit
>>> with PAE. I another step I downloaded source-code for gdal-1.9.2 and added
>>> needed packed with:
>>> *cd ~/Desktop/gdal-mod* <--move cursor to the created folder.
>>> *apt-get source gdal-bin *<--download source-cod from my respositories
>>> (same as my binary installed on my system, into the folder I stand in
>>> ~/Desktop/gdal-mod)
>>> *sudo apt-get build-dep gdal* <--geting dependencies so my system can
>>> build the package gdal.
>>> From https://github.com/usgin/ncgmp/wiki/Installation-Example I found
>>> this example
>>> 1.
>>> *cd ~/downloads *<--change to the folder with the downloaded driver
>>> from ESRI*
>>> 2.
>>> *tar xzf FileGDB_API_1_2-64.tar.gz *<--unpacking
>>> 3.
>>> *cd ~/downloads/FileGDB_API/lib *<--goes to a file in the unpacked
>>> FileGDB*
>>> 4.
>>> *ln -s libfgdbunixrtl.so libfgdblinuxrtl.so <--made a symbolic link
>>> in the folder lib because ESRI change the name.*
>>> 5.
>>> *cd ../..* <--up 2 levels*
>>> 6.
>>> *tar xvf gdal-1.9.0.tar.gz *<--unpacking, I have a newer file*
>>> 7.
>>> *cd gdal-1.9.0 *
>>> 8.
>>> *./configure --with-pg=/usr/bin/pg_config
>>> --with-fgdb=/home/ubuntu/downloads/FileGDB_API
>>> --with-geos=/usr/local/bin/geos-config
>>> --with-static-proj4=/usr/local/lib/libproj.a --with-python *
>>> 9.
>>> *make *
>>> 10.
>>> *sudo make install*
>>> First a question! If I make a 'make install', and if it don't work, how
>>> can i change back to my original gdal-bin?
>>> Second. Does this install libFileGDBAPI.so (Read a tutorial, there they
>>> said that libFileGDBAPI.so should be install in it default directory,
>>> which I don't know where it is...
>>> 6. I have a newer version of gdal (1.9.2) and I have the 32-bit
>>> version on this machine. The swift '--with' in this example above are not
>>> so accurate for my system, I think? What does '--with' really do? Does it
>>> create links in gdal or does it more?
>>> Does someone know which swift '--with ' I should have or are necessaryor good to have? Do the FileGDB also get compiled at the same time?
>>> I seach my system and change the path in the example: first where I
>>> have my FileGDB_API and then some other files have also a different
>>> path? Do I need all this --with, or does a default file add it?
>>> My modified '--with', if it's needed?
>>> --with-fgdb=/home/Joni/Desktop/gdal-mod/FileGDB_API
>>> --with-geos=/usr/bin/geos-config --with-static-proj4=/usr/lib/libproj.a
>>> --with-python
>>> If I don't add anything more than, my FilGDB_API, there the source-code
>>> are, does there are any 'Default setting', so It work as now? I had a
>>> Postgis config-file as in the example. In this example they had
>>> compiled a geos package, but my system did have libgeos and a geos-config
>>> file in above blue directory. The '*--with-static-proj4=/usr/
>>> local/lib/libproj.a**' *have I changed to another *path*, there I find a
>>> * **libproj.a** *file.
>>> Hope someone can explain little..
>>> /Cheers
>>> Johan
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121115/cc94f474/attachment.html>
