[Qgis-user] qgis and Large Format Print
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Nov 15 02:50:39 PST 2012
Hi Régis
I can confirm it is a memory issue and should work with 64bit systems
(note: on windows you need a real 64bit build, a 32bit build will have
the memory problems even if it runs on 64bit hardware).
Regards,
Marco
On 15.11.2012 10:41, haubourg wrote:
> I confirm issue on both 1.8 and master.
> It is related to these tickets:
> http://hub.qgis.org/issues/3687
> http://hub.qgis.org/issues/5840
> http://hub.qgis.org/issues/4821
> http://hub.qgis.org/issues/6498
> I suppose we have problem with large memory usage on 32 bits platforms if it
> exceeds memory allowed. If confirmed, maybe this should be solved by using
> clustered temporary files so that it never exceeds max allowed memory in OS.
> All this need further investigations. I'm ready to fund this but that would
> help a lot if somebody confirm that this is a memory issue.. I don't know
> how to monitor this by myself.
> Régis
> View this message in context: http://osgeo-org.1560.n6.nabble.com/qgis-and-Large-Format-Print-tp5016300p5016544.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
