[Qgis-user] qgis and Large Format Print
G. Allegri giohappy at gmail.com
Thu Nov 15 02:52:38 PST 2012
> I can confirm it is a memory issue and should work with 64bit systems
> (note: on windows you need a real 64bit build, a 32bit build will have the
> memory problems even if it runs on 64bit hardware).
It works with my *real* 64 bit Windows :)
giovanni
> Regards,
> Marco
> On 15.11.2012 10:41, haubourg wrote:
>> I confirm issue on both 1.8 and master.
>> It is related to these tickets:
>> http://hub.qgis.org/issues/**3687 <http://hub.qgis.org/issues/3687>
>> http://hub.qgis.org/issues/**5840 <http://hub.qgis.org/issues/5840>
>> http://hub.qgis.org/issues/**4821 <http://hub.qgis.org/issues/4821>
>> http://hub.qgis.org/issues/**6498 <http://hub.qgis.org/issues/6498>
>> I suppose we have problem with large memory usage on 32 bits platforms if
>> it
>> exceeds memory allowed. If confirmed, maybe this should be solved by using
>> clustered temporary files so that it never exceeds max allowed memory in
>> OS.
>> All this need further investigations. I'm ready to fund this but that
>> would
>> help a lot if somebody confirm that this is a memory issue.. I don't know
>> how to monitor this by myself.
>> Régis
>> View this message in context: http://osgeo-org.1560.n6.**
>> nabble.com/qgis-and-Large-**Format-Print-**tp5016300p5016544.html<http://osgeo-org.1560.n6.nabble.com/qgis-and-Large-Format-Print-tp5016300p5016544.html>
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.**ch <marco.hugentobler at sourcepole.ch>
> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121115/95d93b22/attachment.html>
