[Qgis-user] Set relative path [QGIS 1.8.0 on Win XP]
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Nov 15 07:57:51 PST 2012
Hi Raffaella,
I leave others to deal with absolute versus relative paths, however you can
open the .qgis file itself in notepad and use search and replace to replace
the paths that way. So search for E:\gis_folder\ and replace with
"C:\newfolder\" for instance.
Jonathan
On 15 November 2012 15:27, Raffaella Sanna <raffaellasanna at yahoo.it> wrote:
>  Hi!
> I have some problem working with relative path.
> My QGIS project is stored with a path like this: E:/GIS_folder/Qgis.qgs,
> and all GIS data are in E:/GIS_folder/DATA_folder, so project and data are
> stored in the same folder.
> I saved this project with relative path, from 'project properties' ->
> 'save relative path', but when I copy all the folder "GIS_folder" on
> another pc (on C: disk) and I open the project, all shapefiles are still
> linked to my pc (E:, not C:).
> Is it possible to make the project on other pc, without recall all the
> shapefiles' path?
> Thank you,
> Raffaella
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121115/83d1390e/attachment.html>
