[Qgis-user] qgis and Large Format Print
G. Allegri giohappy at gmail.com
Fri Nov 16 02:21:05 PST 2012
Hi Giovanni,
> I was refering to swapping method used by Postgis or FME uses for handling
> large computations. Temporary files are segmented in files that size less
> than 2Go.. If not, you will encounter same 32 bits OS limitations.
> Just have a look at /pgsql_tmp of a postgis cluster when running huge
> queries for example. (SQL WITH RECURSIVE uses it lot).
Ok, thanks. I wanted just a confirm we were referring to the same thing ;)
giovanni
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121116/c24e1f7a/attachment.html>
