[Qgis-user] Problem installing Profile plugin
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 19 08:37:50 PST 2012
I have uploaded 3.5.2 version of profile tool, which fixes all issues
identified recently. Should work on mac and linux with matplotlib 1.0
and 1.1.1
Etienne
On Tue, Nov 6, 2012 at 7:23 PM, JLancaster <jllancast at gmail.com> wrote:
> matplotlib 1.1.1. I used the Kyngchaos installer.
> Thanks for your work on this. An essential tool for my work.
> JD
> Etienne Tourigny-3 wrote
>> uhhhhhhhhhh ...
>> please, what is you matplotlib version?
>> thanks
>> Etienne
>> On Tue, Nov 6, 2012 at 7:03 PM, JD Lancaster <
>> jllancast@
>> > wrote:
>>>> Hi,
>>>> sorry for the delay... I have just uploaded version 0.5.0
>>>> (profiletool) which fixes this issue, as well as 1.9 compatibility and
>>>> other UI fixes.
>>>> You need to enable Experimental plugins to get this new version -
>>>> please test it and give me your feedback.
>>>> Regards,
>>>> Etuenne
>>> Hi there,
>>> I installed, ran, and received the following error (MACOSX 10.6.8, QGIS
>>> 1.8.0):
>>> An error has occured while executing Python code:
>>> Traceback (most recent call last):
>>> File
>>> "/Users/jdlancaster/.qgis//python/plugins/profiletool/profileplugin.py",
>>> line 278, in changePlotLibrary
>>> self.wdg.addPlotWidget(self.plotlibrary)
>>> File
>>> "/Users/jdlancaster/.qgis//python/plugins/profiletool/ui/ui_ptdockwidget.py",
>>> line 143, in addPlotWidget
>>> self.plotWdg = PlottingTool().changePlotWidget("Matplotlib",
>>> self.frame_for_plot)
>>> File
>>> "/Users/jdlancaster/.qgis//python/plugins/profiletool/tools/plottingtool.py",
>>> line 82, in changePlotWidget
>>> fig = Figure( (1.0, 1.0), linewidth=0.0, subplotpars =
>>> figure.SubplotParams(left=0, bottom=0, right=1, top=1, wspace=0,
>>> hspace=0) )
>>> NameError: global name 'figure' is not defined
>>> Python version:
>>> 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
>>> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
>>> QGIS version:
>>> 1.8.0-Lisboa Lisboa,
>>> Python path:
>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>> '/Users/jdlancaster/.qgis//python',
>>> '/Users/jdlancaster/.qgis//python/plugins',
>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>> '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.7',
>>> '/Library/Python/2.7/site-packages/numpy-override',
>>> '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.7/site-packages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>> '/Library/Python/2.7/site-packages',
>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools',
>>> '/Users/jdlancaster/Desktop']
>>> Qgis-user mailing list
>> Qgis-user at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user at .osgeo
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-installing-Profile-plugin-tp5007211p5014391.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
