[Qgis-user] MINSCALE, MAXSCALE WMS
Sylvia Preuß
sylvia.preuss at obk.de
Tue Nov 20 03:07:19 PST 2012
Thank you very much for your explanation and the link! Now I understand.
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: Tuesday, November 20, 2012 11:33 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] MINSCALE, MAXSCALE WMS
Moin Sylvia,
On Tue, 20. Nov 2012 at 11:12:58 +0100, Sylvia Preuß wrote:
> in my webmapservice (WMS *.map) I have set MINSCALEDENOM 5000 and
> MAXSCALEDENOM 50000 in the layer section. Now I added this WMS-layer in
> qgis and the range is 1:6666 til 1:66666 instead of 1:5000 til 1:50000.
I
> testet other WMS-services and it's always a similar behavior. It's not
> always times 1,33333. but close. Has anybody experienced the same or
knows
> a way out?
The scale you see in QGIS is the scale on screen based on the display's
resolution. The scale the WMS calculates is based on a different fixed
"artificial" resolution. Therefore the scale QGIS shows is not the
scale the WMS calculates when figuring out what to render.
As neither the scale nor the resolution are specified in the WMS request,
there's not much we can do. QGIS server was extended to support a
non-standard DPI parameter to solve that.
See also: http://hub.qgis.org/issues/6430
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Der E-Mail-Dienst des Oberbergischen Kreises dient ausschliesslich der dienstlichen Kommunikation.
Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des Oberbergischen Kreises.
Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf Ihre Nachricht hat. Fuer Berufsgeheimnistraeger gelten abweichende Regelungen.
Es wird ausserdem darauf hingewiesen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschluesselung unsicher ist, da fuer unberechtigte Dritte grundsaetzlich die Moeglichkeit der Kenntnisnahme und Manipulation besteht.
Es wird deshalb keine Verantwortung fuer den Inhalt dieser Nachricht uebernommen, da eine Manipulation nicht ausgeschlossen werden kann.
Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen, dass Anlagen dieser E-Mail virusgeprueft sind, wird empfohlen, anhaengende Dateien vor dem Oeffnen durch Ihr eigenes Virus-Programm zu pruefen, da keinerlei Haftung fuer Schaeden uebernommen wird, die infolge etwaiger Software-Viren entstehen koennten.
Der Inhalt dieser E-Mail ist ausschliesslich fuer die bezeichnete Person bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der Kenntnisnahme, Veroeffentlichungg, Vervielfaeltigung oder Weitergabe des Inhalts dieser E-Mail unzulaessig ist. In diesem Fall wird darum gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
