[Qgis-user] qgis and Large Format Print
Ramon Andiñach custard at westnet.com.au
Thu Nov 22 19:42:41 PST 2012
On 22/11/2012, at 18:18, haubourg <regis.haubourg at eau-adour-garonne.fr> wrote:
> <https://www.dropbox.com/sh/zg4zidwab83ym0d/VpxPA3euLI/QGIS_CRASH_COMPOSER>
> here are my firsts conclusions:
> - Making a fresh install of latest master with no plugin or setting *do not
> often lead to crash (once only for 20-30 exports), since when pdf or image
> raster if resolution is > 300 dpi, then printing just.. does nothing except
> creating an empty pdf.*
> Two months ago, I had QGis computing several minutes and leading to a crash.
> *Something has changed! No crash, but still no usable export *
> - PDF Vector export has a 'tiling' issue of raster background. It seems to
> consume less ressources than raster printing.
> - image export do warn user if memory usage is high. PDF export should do
> the same. BUT, image export warns you, and does nothing.. just like pdf
> export. no image is generated
> I would be pleased to have some feedbacks on your platforms and versions..
> We reallly need to consolidate exports. Mapping in QGIS is really often
> dedicated to export and printing.. We need it stable.
> Régis
Well done!
I've just worked through your notes on my OSGeo4w master - 3700d84 (unfortunately not a fresh install, might try later) and actually had crashes where you did.
I did not get any blank PDFs though.
Where your vector exports about twice as big as the raster versions?
Is that expected?
-ramon.
