[Qgis-user] Table Join in QGIS Master
Filipe Dias filipesdias at gmail.com
Fri Nov 23 01:37:55 PST 2012
Hi Marco
Yes I think it is better that way. And how about adding a small suffix (eg.
"_a" or "_j") instead of the name of the table? If the field's names are
small enough it would still be possible to distinguish between "original"
and "joined" fields.
Tks
Regards
On Fri, Nov 23, 2012 at 9:12 AM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
>  Hi Filipe
> Yes, it is intended behaviour to better distinguish fields with the same
> names. Maybe it would be better to add the table name last, then it would
> get trimmed away?
> Regards,
> Marco
> On 23.11.2012 09:49, Filipe Dias wrote:
> Dear all,
> I tried to join a .csv and .dbf table (table1 with FieldA and FieldB) with
> a shapefile with Field A and Field B. The joined fields in the resulting
> shapefile were named table1FieldA and table2FieldB. In previous versions
> QGIS simply added FieldA and FieldB. Is this the new and intended behaviour?
> If yes, I dont think its a good idea, because if the table field''s names
> are relatively long, they will be trimmed in the final shapefiles eg.
> table1Fie.
> QGIS Master (today's version) and Linux Ubuntu 12.04
> Tks
> Best regards
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121123/b8774009/attachment.html>
