[Qgis-user] qgis and Large Format Print
Ramon AndiƱach custard at westnet.com.au
Fri Nov 23 15:38:51 PST 2012
On 23/11/2012, at 18:19 , haubourg wrote:
> Hi,
> on XP, I installed shapely as described:
> - systematic crashes with pdf raster export 400 dpi. Memory usage going up
> to 762Mo (on 4Go) when crashing. When crashing, I hear HDD swapping a lot
> (confirmed on task manager).
> Composer screen starts a refresh and goes blank. at the same time, I get a
> CPU peak to 100 %, and then crash message coming
> - 300 dpi pdf raster export is generated
> -  500 dpi does nothing, only a small CPU peak. Blank pdf is generated (2Ko)
> Then I uninstalled shapely wiht osgeo installer. Crashes keep on .. Not sure
> if I uninstalled correctly.
Poot. Oh, well, so much for Friday afternoon optimism.
> I think we are not reproducing all cases but we start to have something
> reproducible. If others confirm, we could start to track it in hub.qgis.org?
Yes, definitely. What you've made there is a project that reliably crashes the composer.
-ramon.
