[Qgis-user] call grass modules via qgis python console - Sextante plugin
G. Allegri giohappy at gmail.com
Sun Nov 25 02:51:44 PST 2012
The method suggested by Salvatore is a shortcut to a set of imports
required to run the Sextante methods.
You would obtain the same, only for alglist(), correcting your import to
# from sextante.core.Sextante import alglist
because the method is in the Sextante module, but is not a Sextante class
method.
Anyway, doing as Salvatore suggests, you obtain directly all what you need
giovanni
Sent from Nexus
Il giorno 25/nov/2012 00:32, "S. Koukoulas (lists)" <sotkouklistes at gmail.com>
ha scritto:
> I am trying to run grass commands through the python console using
> sextante and following this example:
> example:
> #import sextante python bindings
> from sextante.core.Sextante import Sextante
> #search available modules -- all
> Sextante.alglist()
> but I am getting the following error at Sextante.alglist() ... any help?
> >>> Sextante.alglist()
> Traceback (most recent call last):
> File "<input>", line 1, in <module>
> AttributeError: class Sextante has no attribute 'alglist'
> thanks,
> sotiris
> QGIS 1.8, Sextante 1.0.8
> OS:  Linux 3.6.6-1.fc17.x86_64 x86_64
> System:  Fedora release 17 (Beefy Miracle)
> KDE:  4.9.3
> On 08/10/2012 07:26 PM, richard burcher wrote:
> > Hi maning,
> > Take a look at Sextante plugin. Can call grass modules from python
> console
> > very easily.
> > example:
> > #search avaible modules -- all
> > Sextante.alglist()
> > #search specific
> > Sextante.alglist("voronoi")
> > [output] v.voronoi - Creates a Voronoi diagram from an input vector map
> > containing points or centroids.--->grass:v.voronoi
> > #get help on alg inputs
> > Sextante.alghelp("grass:v.voronoi")
> > [output] ALGORITHM: v.voronoi - Creates a Voronoi diagram from an input
> > vector map containing points or centroids.
> >         input <ParameterVector>
> >         -l <ParameterBoolean>
> >         -t <ParameterBoolean>
> >         GRASS_REGION_PARAMETER <ParameterExtent>
> >         GRASS_REGION_CELLSIZE_PARAMETER <ParameterNumber>
> >         output <OutputVector>
> > #run algorithm
> > Sextante.runalg("grass:v.voronoi",[follow from Sextante.alghelp output])
> > Use the svn update of Sextante. Checkout my blog post on setting up svn
> for
> > this
> http://geotechrichard.com/2012/06/08/how-to-keep-pace-with-qgis-sextante-svn-of-course/
> > Cheers,
> > Richard
> > View this message in context:
> http://osgeo-org.1560.n6.nabble.com/call-grass-modules-via-qgis-python-console-tp4994410p4994471.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121125/f7b1b430/attachment.html>
