[Qgis-user] call grass modules via qgis python console - Sextante plugin
S. Koukoulas (lists)
sotkouklistes at gmail.com
Sun Nov 25 11:44:14 PST 2012
great! here is the example that worked fine:
#Example with GRASS (through python console and sextante)
# load the DEM in QGIS
import sextante
# define dem as the active raster layer (PyQGIS documentation provides
alternative examples as well)
dem = qgis.utils.iface.activeLayer()
# optional - if you need to find out the correct syntax
sextante.alghelp("grass:r.slope")
sextante.runalg("grass:r.slope", dem, None, None, 1, 0, 1,
"657062.140513,726286.390884,4315084.44829,4362331.68379", 90,
"\yourfolder\slopegrasstest.tif")
Extent can be found by :
dem.extent().toString()
and the output is given in a Xmin,Ymin:Xmax,Ymax format,
where in the slope algorithm above, you need to input the
"Xmin,Xmax,Ymin,Ymax" format.
many thanks again,
sotiris
On 11/25/2012 02:44 AM, Salvatore Larosa wrote:
> Hi,
> 2012/11/25 S. Koukoulas (lists) <sotkouklistes at gmail.com
> <mailto:sotkouklistes at gmail.com>>
> I am trying to run grass commands through the python console using
> sextante and following this example:
> example:
> #import sextante python bindings
> from sextante.core.Sextante import Sextante
> #search available modules -- all
> Sextante.alglist()
> now is enough run:
> >>> import sextante ## see link below[1]
> and then:
> >>> sextante.alglist()
> Regards,
> -SL
> [1] -
> http://docs.qgis.org/html/it/docs/user_manual/sextante/console.html#calling-sextante-from-the-python-console
> but I am getting the following error at Sextante.alglist() ... any
> help?
> >>> Sextante.alglist()
> Traceback (most recent call last):
> File "<input>", line 1, in <module>
> AttributeError: class Sextante has no attribute 'alglist'
> thanks,
> sotiris
> QGIS 1.8, Sextante 1.0.8
> OS: Linux 3.6.6-1.fc17.x86_64 x86_64
> System: Fedora release 17 (Beefy Miracle)
> KDE: 4.9.3
> On 08/10/2012 07:26 PM, richard burcher wrote:
> > Hi maning,
> > Take a look at Sextante plugin. Can call grass modules from
> python console
> > very easily.
> > example:
> > #search avaible modules -- all
> > Sextante.alglist()
> > #search specific
> > Sextante.alglist("voronoi")
> > [output] v.voronoi - Creates a Voronoi diagram from an input
> vector map
> > containing points or centroids.--->grass:v.voronoi
> > #get help on alg inputs
> > Sextante.alghelp("grass:v.voronoi")
> > [output] ALGORITHM: v.voronoi - Creates a Voronoi diagram from
> an input
> > vector map containing points or centroids.
> > input <ParameterVector>
> > -l <ParameterBoolean>
> > -t <ParameterBoolean>
> > GRASS_REGION_PARAMETER <ParameterExtent>
> > GRASS_REGION_CELLSIZE_PARAMETER <ParameterNumber>
> > output <OutputVector>
> > #run algorithm
> > Sextante.runalg("grass:v.voronoi",[follow from Sextante.alghelp
> output])
> > Use the svn update of Sextante. Checkout my blog post on setting
> up svn for
> > this
> http://geotechrichard.com/2012/06/08/how-to-keep-pace-with-qgis-sextante-svn-of-course/
> > Cheers,
> > Richard
> > View this message in context:
> http://osgeo-org.1560.n6.nabble.com/call-grass-modules-via-qgis-python-console-tp4994410p4994471.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
