[Qgis-user] Qgis crashes on File dialog
Donovan Cameron
sault.don at gmail.com
Mon Nov 26 14:12:56 PST 2012
I had a similar issue, but mine was because I had the wrong version of qt
installed.
One thing you could quickly check is the QGIS "About" window.
It says what version of qt that QGIS was compiled against.
Then use your distros package management software (apt?) to verify that the
qt version you have installed matches the qgis compiled version.
If the versions mismatch, you may have to install a matching version of qt.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121126/07025b25/attachment.html>
