[Qgis-user] Qgis crashes on File dialog
Tomáš Vrána tomas.vrana at cemotel.cz
Mon Nov 26 22:43:32 PST 2012
Dne 26.11.2012 23:12, Donovan Cameron napsal(a):
> I had a similar issue, but mine was because I had the wrong version of
> qt installed.
> One thing you could quickly check is the QGIS "About" window.
> It says what version of qt that QGIS was compiled against.
> Then use your distros package management software (apt?) to verify
> that the qt version you have installed matches the qgis compiled version.
> If the versions mismatch, you may have to install a matching version
> of qt.
They match, 4.8.1 in both cases.
Tomas Vrana  <tomas.vrana at cemotel.cz>
Ceskomoravska telekomunikacni s.r.o.
http://www.cemotel.cz/
phone: +420 530 505 505
