[Qgis-user] Qgis crashes on File dialog
Tomáš Vrána tomas.vrana at cemotel.cz
Tue Nov 27 08:20:59 PST 2012
Dne 27.11.2012 17:06, Rudi von Staden napsal(a):
> I've had a similar problem on ubuntu, which I managed to resolve by
> removing package qt-at-spi (a screen reading app for accessibility).
> It also affected Scribus. The solution was provided in the following
> bug report:
> https://bugs.launchpad.net/ubuntu/+source/qt-at-spi/+bug/973332
> On Tue, Nov 27, 2012 at 8:43 AM, Tomáš Vrána <tomas.vrana at cemotel.cz
> <mailto:tomas.vrana at cemotel.cz>> wrote:
>     Dne 26.11.2012 23:12, Donovan Cameron napsal(a):
>         I had a similar issue, but mine was because I had the wrong
>         version of qt installed.
>         One thing you could quickly check is the QGIS "About" window.
>         It says what version of qt that QGIS was compiled against.
>         Then use your distros package management software (apt?) to
>         verify that the qt version you have installed matches the qgis
>         compiled version.
>         If the versions mismatch, you may have to install a matching
>         version of qt.
>     They match, 4.8.1 in both cases.
I am not able to identify corresponding package in openSuse 12.2, but I
can confirm that this problem is realated only to Gnome 3. I switched to
LXDE which is faster to work with anyway. Doesn't happen there.
Tomas Vrana  <tomas.vrana at cemotel.cz>
Ceskomoravska telekomunikacni s.r.o.
http://www.cemotel.cz/
phone: +420 530 505 505
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121127/c0ed767c/attachment.html>
