[Qgis-user] Qgis crashes on File dialog
Tomáš Vrána tomas.vrana at cemotel.cz
Mon Nov 26 22:42:28 PST 2012
Dne 26.11.2012 22:49, Salvatore Larosa napsal(a):
> Hi,
> 2012/11/26 Tomáš Vrána <tomas.vrana at cemotel.cz
> <mailto:tomas.vrana at cemotel.cz>>
>     Hi,
>     using Qgis on openSuse 12.2 and gnome 3, it crashes anytime it
>     tries to open any file dialog (open/save). It seems to be version
>     independent 1.8 as well as 1.9 alpha. I seem to recall there was
>     similar problem about a year ago, but I can't quite remember or
>     find the solution. Needles to say that it is rather annoying.
>     perhaps somoene can help me ?
> I had a similar issue some time ago after I have compiled QGIS with
> FileGDB support,
> it is due to different libxml version between FileGDB and the one on
> my machine.
> Have you compiled FileGDB support ?
> Could you provide any backtrace [1] about crash ?
Here is the trace, taken form 1.9.0
#0  0xb0cf13a6 in ?? () from /usr/lib/libltdl.so.7
#1  0xb0cf2a5b in ?? () from /usr/lib/libltdl.so.7
#2  0xb0cf33d9 in lt_dlopenadvise () from /usr/lib/libltdl.so.7
#3  0xb0cf348a in lt_dlopenext () from /usr/lib/libltdl.so.7
#4  0xb0dbe1bd in ?? () from /usr/lib/libcanberra.so.0
#5  0xb0dbe5a1 in ?? () from /usr/lib/libcanberra.so.0
#6  0xb0db6610 in ?? () from /usr/lib/libcanberra.so.0
#7  0xb0db72cc in ca_context_play_full () from /usr/lib/libcanberra.so.0
#8  0xb0b85a4d in ca_gtk_play_for_widget () from
/usr/lib/libcanberra-gtk.so.0
#9  0xb1862c74 in ?? () from
/usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so
#10 0xb186359e in ?? () from
#11 0xb1345664 in ?? () from /usr/lib/libgdk-x11-2.0.so.0
#12 0xb38a9290 in ?? () from /usr/lib/libglib-2.0.so.0
#13 0xb38ab7d3 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#14 0xb38abb70 in ?? () from /usr/lib/libglib-2.0.so.0
#15 0xb38abfcb in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#16 0xb14960e8 in gtk_dialog_run () from /usr/lib/libgtk-x11-2.0.so.0
#17 0xb4725d0f in ?? () from /usr/lib/libQtGui.so.4
#18 0xb4894201 in QFileDialog::getOpenFileName(QWidget*, QString const&,
QString const&, QString const&, QString*, QFlags<QFileDialog::Option>)
#19 0xbfffdaf8 in ?? ()
(gdb)
which I did compile localy. I am not exactly sure aboput FileGDB, that
seems to be a feature of GDAL rather that Qgis ?
Regards Tom
Tomas Vrana  <tomas.vrana at cemotel.cz>
Ceskomoravska telekomunikacni s.r.o.
http://www.cemotel.cz/
phone: +420 530 505 505
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121127/c7608380/attachment.html>
