[Qgis-user] Qgis crashes on File dialog
Tomáš Vrána
tomas.vrana at cemotel.cz
Tue Nov 27 08:34:16 PST 2012
Dne 27.11.2012 13:19, Salvatore Larosa napsal(a):
> Hi Tomáš,
> 2012/11/27 Tomáš Vrána <tomas.vrana at cemotel.cz
> <mailto:tomas.vrana at cemotel.cz>>
> Dne 26.11.2012 22:49, Salvatore Larosa napsal(a):
>> Hi,
>> 2012/11/26 Tomáš Vrána <tomas.vrana at cemotel.cz
>> Hi,
>> using Qgis on openSuse 12.2 and gnome 3, it crashes anytime
>> it tries to open any file dialog (open/save). It seems to be
>> version independent 1.8 as well as 1.9 alpha. I seem to
>> recall there was similar problem about a year ago, but I
>> can't quite remember or find the solution. Needles to say
>> that it is rather annoying. perhaps somoene can help me ?
>> I had a similar issue some time ago after I have compiled QGIS
>> with FileGDB support,
>> it is due to different libxml version between FileGDB and the one
>> on my machine.
>> Have you compiled FileGDB support ?
>> Could you provide any backtrace [1] about crash ?
> Here is the trace, taken form 1.9.0
> #0 0xb0cf13a6 in ?? () from /usr/lib/libltdl.so.7
> #1 0xb0cf2a5b in ?? () from /usr/lib/libltdl.so.7
> #2 0xb0cf33d9 in lt_dlopenadvise () from /usr/lib/libltdl.so.7
> #3 0xb0cf348a in lt_dlopenext () from /usr/lib/libltdl.so.7
> #4 0xb0dbe1bd in ?? () from /usr/lib/libcanberra.so.0
> #5 0xb0dbe5a1 in ?? () from /usr/lib/libcanberra.so.0
> #6 0xb0db6610 in ?? () from /usr/lib/libcanberra.so.0
> #7 0xb0db72cc in ca_context_play_full () from
> #8 0xb0b85a4d in ca_gtk_play_for_widget () from
> /usr/lib/libcanberra-gtk.so.0
> #9 0xb1862c74 in ?? () from
> /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so
> #10 0xb186359e in ?? () from
> #11 0xb1345664 in ?? () from /usr/lib/libgdk-x11-2.0.so.0
> #12 0xb38a9290 in ?? () from /usr/lib/libglib-2.0.so.0
> #13 0xb38ab7d3 in g_main_context_dispatch () from
> #14 0xb38abb70 in ?? () from /usr/lib/libglib-2.0.so.0
> #15 0xb38abfcb in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
> #16 0xb14960e8 in gtk_dialog_run () from /usr/lib/libgtk-x11-2.0.so.0
> #17 0xb4725d0f in ?? () from /usr/lib/libQtGui.so.4
> #18 0xb4894201 in QFileDialog::getOpenFileName(QWidget*, QString
> const&, QString const&, QString const&, QString*,
> QFlags<QFileDialog::Option>) () from /usr/lib/libQtGui.so.4
> #19 0xbfffdaf8 in ?? ()
> (gdb)
> I am not completely sure about it, but it seems due to libtool
> library, can you try to reinstall it ?
> How do you install QGIS ? self-compiled ?
> which I did compile localy. I am not exactly sure aboput FileGDB,
> that seems to be a feature of GDAL rather that Qgis ?
> Sure, but QGIS is compiled against GDAL so it might be a problem, at
> the least for me it was !
> Regards,
> -SL
I have tested two versions of Qgis - one is self compiled from the
current git master, another is official rpm packege 1.8.0 from
http://download.opensuse.org/repositories/Application:/Geo/ . Both
behave the same way under Gnome3. Libtool and its libraries seem to be
fine, distribution clean. Perhaps libltdl is trying to open some
nonexisting librarary ?
Tom
Tomas Vrana <tomas.vrana at cemotel.cz>
Ceskomoravska telekomunikacni s.r.o.
http://www.cemotel.cz/
phone: +420 530 505 505
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121127/df5dd1c5/attachment.html>
