[Qgis-user] How increase the decimal in attribute table
Alexandre Neto senhor.neto at gmail.com
Thu Nov 29 06:54:06 PST 2012
Hello,
You need to create a new attribute to your layer as Decimal Number,
defining the precision to 15.
Alexandre Neto
On Thu, Nov 29, 2012 at 1:54 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> Actually qgis when show the attribute table of a layer, when the field
> is a float type,
> show only 6 decimal.
> This is not good situation when the field is a double.
> Because the real value is a 15 decimal value.
> So it could happened that two values really distinct but only on a low
> decimal, in the attribute table seem to be equals.
> There is a parameter to increase the decimal showed in the attribute
> table for a double precision field ?
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121129/b7fe6ff0/attachment.html>
