[Qgis-user] How increase the decimal in attribute table
Andrea Peri
aperi2007 at gmail.com
Fri Nov 30 22:52:46 PST 2012
thx for response.
I don't notice the field was effectively 18.5
So no problem. The table correctly show all the decimal not only a
sub-fraction of them.
Sorry for noise.
Andrea
2012/11/29 Alexandre Neto <senhor.neto at gmail.com>:
> Hello,
> You need to create a new attribute to your layer as Decimal Number, defining
> the precision to 15.
> Alexandre Neto
> On Thu, Nov 29, 2012 at 1:54 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> Actually qgis when show the attribute table of a layer, when the field
>> is a float type,
>> show only 6 decimal.
>> This is not good situation when the field is a double.
>> Because the real value is a 15 decimal value.
>> So it could happened that two values really distinct but only on a low
>> decimal, in the attribute table seem to be equals.
>> There is a parameter to increase the decimal showed in the attribute
>> table for a double precision field ?
>> Andrea Peri
>> qwerty àèìòù
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
