[Qgis-user] How increase the decimal in attribute table
Paulo van Breugel p.vanbreugel at gmail.com
Thu Nov 29 07:46:34 PST 2012
What database type are you using? Both shapefiles (dbf tables) and
spatialite layers are showing more then 6 decimals in my case
On Thu, Nov 29, 2012 at 2:54 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> Actually qgis when show the attribute table of a layer, when the field
> is a float type,
> show only 6 decimal.
> This is not good situation when the field is a double.
> Because the real value is a 15 decimal value.
> So it could happened that two values really distinct but only on a low
> decimal, in the attribute table seem to be equals.
> There is a parameter to increase the decimal showed in the attribute
> table for a double precision field ?
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121129/75ca361f/attachment.html>
